    KT
    49 Posts 9 Posters 5.9k Views 9 Watching
    • david57D Offline
      david57
      Here's another, looks like a doll house.
      • david57D Offline
        david57
        A push pull on the right side.
        • soloS Offline
          Very nice and clean images.
          • david57D Offline
            david57
            Using setting #8 for rendering.
            Here's another style. Needs glass on the radius.
            • david57D Offline
              david57
              Messed it up. Deleted parts of mullions on the right by mistake.
                kwistenbiebel
                Hi David,
                Looking better and better.
                A good ground texture will make this more alive.
                I like the crispness of the images so far. Keep those coming.
                • david57D Offline
                  david57
                  Thanks kwistenbiebel.
                  Here's a ground view.
                  • david57D Offline
                    david57
                    • david57D Offline
                      david57
                      Used KT's Instancing tool to populate a sphere with leaves.
                        Really cool idea. and generally speaking, the plants give a nice extra to the images (although the treeline seems to be a bit flat and too roughly cutout)
                        • david57D Offline
                          david57
                          A try at 8 spheres. The one to the far left, was my first test tree.
                          the leafs are to large and to sparce.
                            Nice hedges can also be created this way...
                            • david57D Offline
                              david57
                              Yes hedges and grass, but havent tried grass.
                              Working here on a deserted island, hopeing not, to see what's his name
                              walking through here, in his birthday suit.
                              • majidM Offline
                                majid
                                hi all /david .
                                i tried KT Brush over a bush i separately inserted and merged whit a leaf, and here is the draft render result , maybe it is good for mid-distance foliages . u may improve this idea using flowers ... bushes , trees ...or people ..
                                3rd test
                                • david57D Offline
                                  david57
                                  Tried Clipmaping of leafs, but couldn't get the right results.
                                  • david57D Offline
                                    david57
                                    • david57D Offline
                                      david57
                                      Tree Trunk, Branches,and 10 Leafs were made with a Blender script called Gen3.
                                      Made Components with Trunk, Branches, and only 10 Octagon Leafs in SU.
                                      The same Ten Leafs were used for the Hedges, but smaller.
                                      • david57D Offline
                                        david57
                                        Two more.
                                        • david57D Offline
                                          david57
                                          Here,s another render.
                                          • david57D Offline
                                            david57
                                            Model in the background was not made by me.
                                            Model can be found at
                                            http://archidom.net/ddd/model_S.htm
                                            • 2 / 3
