    Vray and Podium Render
    30 Posts 11 Posters 5.6k Views 11 Watching
      AcesHigh
      what is the bloom technique? How to use it?
      [AcesHigh]
      • soloS Offline
        Nice one Nome, Is this with 1.5b?
        • jenujacobJ Offline
          jenujacob
          @ aces...
          bloom is a post production technique...
          u can find it a tutorial here : http://www.oferz.com/Tutorials/BloomEffect/BloomEffect.html
          • N Offline
            nomeradona
            thank you guys for all your comments and encouragement.
            i tried to post the vray version but it seems the site can only handled maximum of 800pixel. so i need to resize it and use imageshack to host it.
            the bloom... actually i use Post processing using photoshop, i use a slight diffuse glow filter. i found diffuse works better in diffusing the highlights only. if you are blurring the whole image then adjusting the opacity, most likely you will affect even the shadows and mid tones.
            here is a link for my quick tutorial.
            http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=1719221
            now there are some hard areas you dont want to be affected by the filter, therefore you use soft eraser to show the underneath layer.
            i will try to send some more images later using vray and podium.
            even though they are different softwares, i like them both becuase they serve different things. i love podium because its very easy to use and to set up so the learning curve is really quick at the same time its the software im introducing to our school. it really works hand in hand with Su, with regarsds to efficiency and fundametal approach to 3d.
            of course the more we mature, the more we long for realism and i think vray and maxwell has edge on this. but since i have experience with max and vray, i continue this when they released the vray sketchup. at the moment its kinda buggy (particularly in re-mapping).
            the funny thing is why i say they are compatible, vray accept those, reflections assigned with poidum in SU and not only that even the bump map now in 1.5. unofrtunately clipmap works differently.
            nece meeting you all guys here in this forum. ( hi biebel, solo and sepo)
            @solo. it was rendered using the old version 1.41
            • N Offline
              nomeradona
              ok here is the image
              http://img460.imageshack.us/img460/4917/finalmyspacemi2ur6.jpg
              • N Offline
                nomeradona
                here are some more renders
                http://img371.imageshack.us/img371/3296/finalmaybecopyvg4cc8.jpg
                http://img371.imageshack.us/img371/6639/ngoclivingroom4ff4.jpg
                http://img378.imageshack.us/img378/1115/livingroomshowcasemixedaz5.jpg
                http://img460.imageshack.us/img460/6318/villathangloivrayls8.jpg
                  Ross Macintosh
                  nomeradona - I'm gobsmacked! That's some really tasty work. Thanks for sharing and for making the 'bloom' concept easier to understand.
                  Regards, A Fan
                  • boofredlayB Offline
                    boofredlay
                    Very very very nice. 👍
                    • N Offline
                      nomeradona
                      thanks for all your comments. ross thanks for all those things that you share Censored to protect your privacy.
                        dylan
                        These look great.
                        The next to last image with the graphic style lines, is this done in Photoshop? Ive seen this in the past and wondered exactly how it is achieved.
                        http://dmdarchitecture.co.uk/
                        • N Offline
                          nomeradona
                          @ Dylan.. its with photoshop. i think zem had a tutorial on how to combine render image and su render image. i just improvised his technique. anyway the main principle is to export an image using style and a render image. but the view should be the same. then put them on different layers in photoshop. make the opacity of the top level lesser, so that you can see the bottom level. once the top and bottom layer are alligned, you can make the opacity 100% and play with the top level. in my case i use soft eraser and erase the top level. once satisfied, thats it.
                          Censored to protect your privacy. i smiled because i put a big smile on you..
                          • N Offline
                            nomeradona
                            ok here is another one. a night scene showing different light source.
                            http://img108.imageshack.us/img108/9515/lighttestfinalwl6.png
                              dylan
                              @nomeradona said:
                              @dylan... its with photoshop. i think zem had a tutorial on how to combine render image and su render image. i just improvised his technique. anyway the main principle is to export an image using style and a render image. but the view should be the same. then put them on different layers in su. make the opacity of the top level lesser, so that you can see the bottom level. once the top and bottom layer are alligned, you can make the opacity 100% and play with the top level. in my case i use soft eraser and erase the top level. once satisfied, thats it.
                              @modelhead.. i smiled because i put a big smile on you..
                              Thanks for the info, that sounds simple enough, I shall give it a try 👍
                                AcesHigh
                                Is Podium better than Artlantis?
                                [AcesHigh]
                                  sepo
                                  I say it is better but than I would say that wouldn't I. 😄
                                    kwistenbiebel
                                    I think you just said it Sid! 😄
                                    By the way, imho Podium is easier than artlantis ....but there is rumour that a new Artlantis studio is coming up with better output quality than the old one.....so who knows what the near future brings.
                                    • N Offline
                                      nomeradona
                                      to be honest, i havent tried atlantis. but i tried podium since its version 1. i could attest how much it improved and how much easy to set it up and its really joy to do quick thing and with quality images. if you are looking for a software that works hand in hand with SU, i think podium is.
                                        tomsdesk
                                        These really are a joy to behold! Very artistic! Thanks for sharing.
                                        2.5D Trees & Shrubs!
                                        • N Offline
                                          nomeradona
                                          thanks tom for the compliment 😄
                                            AcesHigh
                                            it would be nicer if you guys compared the features of Podium vs those of Artlantis.
                                            [AcesHigh]
