    Vray and Podium Render
    30 Posts 11 Posters 5.3k Views 11 Watching
    • N Offline
      nomeradona
      i jsut want to share some of my vray and podium render using SU. This is my new place using podium render
      http://img412.imageshack.us/img412/9104/mynewplacenb9.jpg
      • jenujacobJ Offline
        jenujacob
        did u use the bloom technique for this one???
        u should post ur Vray renders here too! i am a fan! 😉
          kwistenbiebel
          Great image Nomer !
          Podium still remains a power tool.
          I am also interested to see the Vray version of that space.
          Cool work!
          Cheers,
          Kwistenbiebel
            AcesHigh
            what is the bloom technique? How to use it?
            [AcesHigh]
            • soloS Offline
              Nice one Nome, Is this with 1.5b?
                jenujacob
                @ aces...
                bloom is a post production technique...
                u can find it a tutorial here : http://www.oferz.com/Tutorials/BloomEffect/BloomEffect.html
                • N Offline
                  nomeradona
                  thank you guys for all your comments and encouragement.
                  i tried to post the vray version but it seems the site can only handled maximum of 800pixel. so i need to resize it and use imageshack to host it.
                  the bloom... actually i use Post processing using photoshop, i use a slight diffuse glow filter. i found diffuse works better in diffusing the highlights only. if you are blurring the whole image then adjusting the opacity, most likely you will affect even the shadows and mid tones.
                  here is a link for my quick tutorial.
                  http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=1719221
                  now there are some hard areas you dont want to be affected by the filter, therefore you use soft eraser to show the underneath layer.
                  i will try to send some more images later using vray and podium.
                  even though they are different softwares, i like them both becuase they serve different things. i love podium because its very easy to use and to set up so the learning curve is really quick at the same time its the software im introducing to our school. it really works hand in hand with Su, with regarsds to efficiency and fundametal approach to 3d.
                  of course the more we mature, the more we long for realism and i think vray and maxwell has edge on this. but since i have experience with max and vray, i continue this when they released the vray sketchup. at the moment its kinda buggy (particularly in re-mapping).
                  the funny thing is why i say they are compatible, vray accept those, reflections assigned with poidum in SU and not only that even the bump map now in 1.5. unofrtunately clipmap works differently.
                  nece meeting you all guys here in this forum. ( hi biebel, solo and sepo)
                  @solo. it was rendered using the old version 1.41
                  • N Offline
                    nomeradona
                    ok here is the image
                    http://img460.imageshack.us/img460/4917/finalmyspacemi2ur6.jpg
                    • N Offline
                      nomeradona
                      here are some more renders
                      http://img371.imageshack.us/img371/3296/finalmaybecopyvg4cc8.jpg
                      http://img371.imageshack.us/img371/6639/ngoclivingroom4ff4.jpg
                      http://img378.imageshack.us/img378/1115/livingroomshowcasemixedaz5.jpg
                      http://img460.imageshack.us/img460/6318/villathangloivrayls8.jpg
                        Ross Macintosh
                        nomeradona - I'm gobsmacked! That's some really tasty work. Thanks for sharing and for making the 'bloom' concept easier to understand.
                        Regards, A Fan
                        • boofredlayB Offline
                          boofredlay
                          Very very very nice. 👍
                          • N Offline
                            nomeradona
                            thanks for all your comments. ross thanks for all those things that you share Censored to protect your privacy.
                              dylan
                              These look great.
                              The next to last image with the graphic style lines, is this done in Photoshop? Ive seen this in the past and wondered exactly how it is achieved.
                              http://dmdarchitecture.co.uk/
                              • N Offline
                                nomeradona
                                @ Dylan.. its with photoshop. i think zem had a tutorial on how to combine render image and su render image. i just improvised his technique. anyway the main principle is to export an image using style and a render image. but the view should be the same. then put them on different layers in photoshop. make the opacity of the top level lesser, so that you can see the bottom level. once the top and bottom layer are alligned, you can make the opacity 100% and play with the top level. in my case i use soft eraser and erase the top level. once satisfied, thats it.
                                Censored to protect your privacy. i smiled because i put a big smile on you..
                                • N Offline
                                  nomeradona
                                  ok here is another one. a night scene showing different light source.
                                  http://img108.imageshack.us/img108/9515/lighttestfinalwl6.png
                                    dylan
                                    @nomeradona said:
                                    @dylan... its with photoshop. i think zem had a tutorial on how to combine render image and su render image. i just improvised his technique. anyway the main principle is to export an image using style and a render image. but the view should be the same. then put them on different layers in su. make the opacity of the top level lesser, so that you can see the bottom level. once the top and bottom layer are alligned, you can make the opacity 100% and play with the top level. in my case i use soft eraser and erase the top level. once satisfied, thats it.
                                    @modelhead.. i smiled because i put a big smile on you..
                                    Thanks for the info, that sounds simple enough, I shall give it a try 👍
                                      AcesHigh
                                      Is Podium better than Artlantis?
                                      [AcesHigh]
                                        sepo
                                        I say it is better but than I would say that wouldn't I. 😄
                                          kwistenbiebel
                                          I think you just said it Sid! 😄
                                          By the way, imho Podium is easier than artlantis ....but there is rumour that a new Artlantis studio is coming up with better output quality than the old one.....so who knows what the near future brings.
                                          • N Offline
                                            nomeradona
                                            to be honest, i havent tried atlantis. but i tried podium since its version 1. i could attest how much it improved and how much easy to set it up and its really joy to do quick thing and with quality images. if you are looking for a software that works hand in hand with SU, i think podium is.
