    Lake House
    23 Posts 6 Posters 2.2k Views 6 Watching
    • KrisidiousK Offline
      Krisidious
      Nick...
      you really have all the little details down to bring out the realistic views... you're young but man how you're talented...
      By: Kristoff Rand
      • boofredlayB Offline
        boofredlay
        Nick that is really nice. It shows the house in context and reads well.
        C&C. In my opinion, the windows need some reflection. If you are using PS, just paint some on. Something similar to this:
        http://www.semosigmanu.com/images/houses/Shivelbine_watercolor.jpg
        Nothing fancy just a few brush strokes. The landscape in the foreground seems a bit sterile and the steps off the door to the right need somewhere to land other than grass.
        Overall a great start and a nice home indeed.
        • monsterzeroM Offline
          monsterzero
          Eric, wow. That's a great observation. Looking back at the image, I see how dead the windows look. Reflection of the world around, and possibly a hint of the interior would add a huge amount of life to the scene.
          It's one of those artistic details that someone might miss.
          justin
          monsterzero
          I live stream my work on my graphic novel:
          https://www.youtube.com/@monsterz3r0
          http://infinitemachine.tv/
          https://www.aaatitle.xyz/
            Krisidious
            Nick,
            here's a hint for you...
            1. make a small box in your model... say 5'x5'x5'... 2. now make it a group.
            2. now move it to each corner of your roof, and evelope the entire corner of the roof, the rafter tail, the soffit, the facia...
            3. next, use the cut command to cut the box out of the model.
            4. next open your "roof" group or component.
            5. now, use the Edit>Paste in Place command. this will put the box back in the model exactly where you cut it from.
            6. now, select all of the corner of the roof, the box the roofing the soffit all of it.
            7. next, right click and select intersect all selected.
            8. now select all the corner again, and right click, select create component.
            9. next, right click again on the new component, select saveas... navigate to your component library inside of the Sketchup folder. then navigate to the Roof area in Construction. and save this corner roof as "Gable_End_Pitch_8_12_w_Wrap" or whatever you want...
            now you'll have this little corner in your roof component library, and if you do this on each corner, every time you make a roof, soon you'll have a little library of awesome roof corners, which can be then inserted and entire roofs extended from them.
            that hint turned out a lot bigger than it was supposed too... lol but it is something that can same you loads of time later on...
            anyway keep up the good work
            By: Kristoff Rand
            • N Offline
              Nick W
              Thank you all for your complements and helpful suggestions.
              Justin, I agree totally that it could benefit from more lake view action. πŸ˜„
              Eric, thanks for the great artistic finish tips. πŸ˜„
              And Kris, thanks for the great workflow/library tip. πŸ˜„
              http://www.nrwiesneski.com
              • N Offline
                Nick W
                Kris, that was a very helpful tip for a young buck like me. πŸ˜„ And very much appreciated. I'm like a sponge... a really big, human-shaped sponge.
                Thanks again! I learned a lot from everyone's responses.
                  Krisidious
                  perfecto... exactly what I meant... sometimes I wonder if people understand what I'm saying... I'm not Pro at training like Coen and some of the others here...
                  that's exactly what I intended. those look great.
                  I hope to build a free database of components here... we're working on it behind the scenes...
                  By: Kristoff Rand
                    boofredlay
                    @nick w said:
                    ...I'm like a sponge... a really big, human-shaped sponge.
                    I am just glad your name is not Bob.
                    Nice tip Kris.
                    • N Offline
                      Nick W
                      rev1
                      Thanks for sharing your experience. It's pretty great to have specific suggestions to go back and work on. And techniques to add to my bag of tricks. πŸ˜„
                        boofredlay
                        That is looking great! Way to go.
                          Krisidious
                          looks great... the background fit the drawing well.. although I might suggest... taking your grass texture and using the match color tool to make it not so green as it looks kind of out of season...
                          although with lawns nowadays it could easily be so green in fall...
                          great job making it look like a photo of a real perspective...
                          By: Kristoff Rand
                          • N Offline
                            Nick W
                            I faded down some of the saturation in the grass, trees, background, and bushes. And made some color balance adjustments to the grass. I think they were a bit overblown - in the context of the fall colors, but also in relation to the house they took your eye away from the house a bit, I think.
                            Thanks again for the tips, everyone. Very helpful.
                            • marked001M Offline
                              marked001
                              ah this is looking awesome! crazy how you always think your first pass is great...and then you're able to take it so much further.
                              http://www.revision21vis.com
                              instagram: revi21on
                              • N Offline
                                Nick W
                                I dulled the background one more time and added a little noise overall - I think it ties it together nicely.
                                Thanks for the thorough review πŸ˜„
                                • N Offline
                                  Nick W
                                  Oh, and I added a warming filter overall, too.
                                    Ah, all those picky eyes...
                                    It's really getting nicer and nicer, Nick! Looking forward to further enhancements!
                                    πŸ˜„
                                    • N Offline
                                      Nick W
                                      last changes for today... this time for sure! πŸ˜„
                                      I removed the warming filter on the sky and dialed it back a little for the rest. James and others, thanks for the picky eyes. πŸ˜„
                                      • N Offline
                                        Nick W
                                        I think this latest version really pops the house and looks less "cartoony". Thanks so much for your input, friends. πŸ˜„
                                          Krisidious
                                          "the music of the pearly gates plays...."
                                          looks very real... awesome job... I say DONE! send it to print...
                                          By: Kristoff Rand
                                            boofredlay
                                            Forgot to mention, nice glass reflec.
                                            Cheers
                                            I second that.
