    Easy digital watercolor
    83 Posts 25 Posters 153.3k Views 25 Watching
    • tinanneT
      tinanne
      Yes, coming along nicely. The line work is nice, but a little to "uniformally wavy" for me....
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
        mateo soletic
        Nice images majid, you are definately on the right track. I would also suggest
        the frequent use of the smudge tool as well as use of diferent styles as layers
        in order to create a more uniformal and hand drawn look.
        Concept Illustrations
        • majidM
          majid
          thanks again . yes i used the smuge tool to some part before texturing and it worked . nice πŸ˜„
          • majidM
            majid
            and here is the PR render of the first subject . i did it not too tight , the floor bump is too heavy , and the TV & vase & plants R not good at all ... btw here it is
            PR render
            • majidM
              majid
              my action is based on wet WC tech...and here it is:
              as tom said (and the others ) smudge tool before texturing has great results . pls remove (.rb) part....
              put it at the actions folder and load it at PS
              • majidM
                majid
                ok everyone . just remove the rb extention , copy the action @ action folder of ur photoshop , load it and play .... enjoy
                • majidM
                  majid
                  did anyone tried the photoshop actions i posted? ( remove the rb extention , load from PhotoShop Action pallete ) , play .njoy ... & give ur feedback plz
                  • jenujacobJ
                    jenujacob
                    i downloaded the action.. but didnt try it yet.. but i will definitely try it and post the results here... thank u majid!!!
                      alpro
                      Thanks majid!!, just downloaded and ran, can't wait to play around with it a little more.
                      Mike
                      • majidM
                        majid
                        pls use it over a su pure result ( not a render ) try to duge/burn T light and shadows befor the action is applied . just copy the background layer and then start the action.
                        also i have tried the second generation of my action that works better on SU outpots !and i think it is better for architectural jobs ... here r the results
                          alpro
                          Here is the action applied to SU output, I will try and play with the dodge and burn tools when I get a little more time. Thanks again.
                          Mike
                          • majidM
                            majid
                            a easier way is direct watercolor outpot of su ( the styles) . i had post some new styles here : (i myself like draftsman+watercolor style)
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=42&t=5293&p=29685#p29685
                            • majidM
                              majid
                              try these new styles plz
                              watercolor
                              • majidM
                                majid
                                here u can try the watercolor directly by the su . by the way my last PS action is in progress
                                • majidM
                                  majid
                                  here is the last try . a photon map quick render as light/shadow layer overthe su pure image layer ,blended . and then action (last action that is in progress)... and here is the result
                                  • X
                                    XXXXXXXXXXXXXXXXXXXX
                                    These are nice. I have also been working on creating a decent photoshop action that simulates watercolor, which is not an easy task. I'll have to give your style a try in CS3...thanks!
                                    I have a photoshop action that I have used for the last 3 years or so (prior to my use of SketchUp), but it's still a work in progress. It's similar to Dennis' technique that layers b/w, colored, shadowed in seperate layers, only this does it all for you. You put in a colored rendering that you want to watercolor, hit the action and answer a few questions along the way to get the end result just the way you want it. You "paint" away the white exposing the the right amount of coloring you want. It works pretty well, but I'm still not entirely happy with it, however, I just haven't had the time to really finish working out exactly how I want it.
                                    I've attached a close up sample below. This piece was taken from an illustration that had the linework created in cad and then colored in photoshop. No fancy texturing or brushwork was done. Everything you see was done in the script.
                                    When I get some free time, I'll try and finish it and maybe it'll be presentable enough to share.
                                    • majidM
                                      majid
                                      the hard part of the work is simulating human smartness! human knows were to loose or tight work ( i.e trees r ignored to be detailed by the man ) .... btw if good texturing in SU = good result by PS action ... .very well done! really nice job u did!! πŸ˜„
                                      • majidM
                                        majid
                                        the important point is that keep some part textures ( architectural parts) and ignore and loose work on other areas... what do u suggest about?
                                        • majidM
                                          majid
                                          is ther any body how has a way <tip , trick... to solve the peoblem??
                                          • majidM
                                            majid
                                            here is the dennis way , expanded using clay render from kt as a light layer. any suggestion?
                                            • 1 / 5
