    Easy digital watercolor
    83 Posts 25 Posters 152.6k Views 25 Watching
      alexander
      πŸ‘ not bad, not bad at all πŸ‘
      lovely colors..
      • tinanneT Offline
        tinanne
        Yes, coming along nicely. The line work is nice, but a little to "uniformally wavy" for me....
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
          mateo soletic
          Nice images majid, you are definately on the right track. I would also suggest
          the frequent use of the smudge tool as well as use of diferent styles as layers
          in order to create a more uniformal and hand drawn look.
          Concept Illustrations
          • majidM Offline
            majid
            thanks again . yes i used the smuge tool to some part before texturing and it worked . nice πŸ˜„
            • majidM Offline
              majid
              and here is the PR render of the first subject . i did it not too tight , the floor bump is too heavy , and the TV & vase & plants R not good at all ... btw here it is
              PR render
              • majidM Offline
                majid
                my action is based on wet WC tech...and here it is:
                as tom said (and the others ) smudge tool before texturing has great results . pls remove (.rb) part....
                put it at the actions folder and load it at PS
                • majidM Offline
                  majid
                  ok everyone . just remove the rb extention , copy the action @ action folder of ur photoshop , load it and play .... enjoy
                  • majidM Offline
                    majid
                    did anyone tried the photoshop actions i posted? ( remove the rb extention , load from PhotoShop Action pallete ) , play .njoy ... & give ur feedback plz
                    • jenujacobJ Offline
                      jenujacob
                      i downloaded the action.. but didnt try it yet.. but i will definitely try it and post the results here... thank u majid!!!
                        alpro
                        Thanks majid!!, just downloaded and ran, can't wait to play around with it a little more.
                        Mike
                        • majidM Offline
                          majid
                          pls use it over a su pure result ( not a render ) try to duge/burn T light and shadows befor the action is applied . just copy the background layer and then start the action.
                          also i have tried the second generation of my action that works better on SU outpots !and i think it is better for architectural jobs ... here r the results
                            alpro
                            Here is the action applied to SU output, I will try and play with the dodge and burn tools when I get a little more time. Thanks again.
                            Mike
                            • majidM Offline
                              majid
                              a easier way is direct watercolor outpot of su ( the styles) . i had post some new styles here : (i myself like draftsman+watercolor style)
                              http://www.sketchucation.com/forums/scf/viewtopic.php?f=42&t=5293&p=29685#p29685
                              • majidM Offline
                                majid
                                try these new styles plz
                                watercolor
                                • majidM Offline
                                  majid
                                  here u can try the watercolor directly by the su . by the way my last PS action is in progress
                                  • majidM Offline
                                    majid
                                    here is the last try . a photon map quick render as light/shadow layer overthe su pure image layer ,blended . and then action (last action that is in progress)... and here is the result
                                    • X Offline
                                      XXXXXXXXXXXXXXXXXXXX
                                      These are nice. I have also been working on creating a decent photoshop action that simulates watercolor, which is not an easy task. I'll have to give your style a try in CS3...thanks!
                                      I have a photoshop action that I have used for the last 3 years or so (prior to my use of SketchUp), but it's still a work in progress. It's similar to Dennis' technique that layers b/w, colored, shadowed in seperate layers, only this does it all for you. You put in a colored rendering that you want to watercolor, hit the action and answer a few questions along the way to get the end result just the way you want it. You "paint" away the white exposing the the right amount of coloring you want. It works pretty well, but I'm still not entirely happy with it, however, I just haven't had the time to really finish working out exactly how I want it.
                                      I've attached a close up sample below. This piece was taken from an illustration that had the linework created in cad and then colored in photoshop. No fancy texturing or brushwork was done. Everything you see was done in the script.
                                      When I get some free time, I'll try and finish it and maybe it'll be presentable enough to share.
                                      • majidM Offline
                                        majid
                                        the hard part of the work is simulating human smartness! human knows were to loose or tight work ( i.e trees r ignored to be detailed by the man ) .... btw if good texturing in SU = good result by PS action ... .very well done! really nice job u did!! πŸ˜„
                                        • majidM Offline
                                          majid
                                          the important point is that keep some part textures ( architectural parts) and ignore and loose work on other areas... what do u suggest about?
                                          • majidM Offline
                                            majid
                                            is ther any body how has a way <tip , trick... to solve the peoblem??
                                            • 1 / 5
