    Easy Podium render...
    13 Posts 8 Posters 1.3k Views 8 Watching
      Ross Macintosh
      Yesterday I decided to have another look at Podium. I'm glad I did because the beta of 1.5 offers quite a bit. Over time I've realized that for a renderer to fit into my workflow it's going to have be easy. I don't need to achieve perfection -- just something I can use in a reasonable amount of time. The new Podium might just be the ticket.
      For the attached image I just gave the pool water face some reflectivity and then told Podium to render with the 'noisy' setting. I then left the room to watch some tv with the family. Upon returning I found Podium had completed 150 passes and noise wasn't an issue in the render so I stopped it. I opened the jpg in Xara Xtreme Pro and added a little sharpening and adjusted the brightness and contrast slightly. That was about 1 minute of post processing. I'm pleased with the result especially since I know Podium is capable of better. I realize for instance that adding some bump mapping might have made a better result. Adding reflectivity to the glass would likely improve the results too. Even without such touches I'm pleased that it did so well basically just rendering the straight SU model.
      Regards, Ross
      • soloS Offline
        a water bump would make the pool come alive. If you need any textures, bumps etc, feel free to ask i have a few good ones.
        excellent render.
        • N Offline
          nomeradona
          and even you can use your existing water texture. just go to the material editor and rename your water texture. for example if the name of texture is "water.jpg" all you need to do is change it to water_bump.jpg. that it podium will automatically remind itself that you are using bump map. you can also increase bumpby assigning bump number like this "water_bump1.jpg", water_bump2.jpg.....
          • tinanneT Offline
            tinanne
            Very impressive Ross. I'm also excited about this program.
            Executive Director : American Society of Architectural Illustrators
            AIP 30 Competition opens soon. ASAI.org
            Architectural Rendering
              kwick7
              1.5 isn't open beta yet, right? I started giving Podium a try again this week, but render time for me has been extremely slow. I want to use it, hopefully 1.5 is what I need, otherwise I'll just stick with Kerkythea for now.
              http://www.bigmug.net
                Ross Macintosh
                Hi kwick7 -- all registered users of Podium have access to the Beta. If your getting along fine with Kerkythea then you may never need Podium. If I'm not mistaken, Podium uses the Kerkythea rendering engine so it will never be any faster than it. What Podium does have going for it is the simplified user interface and the way it works inside SU as a plugin.
                Thanks for the feedback Tina, Solo and nomeradona. The tips are appreciated too.
                Regards, Ross
                • GarethG Offline
                  Gareth
                  Nice work...!!
                  This is the first time I have been in here since the old SU Forum.
                  It's good to recognise some of the old names.....!!
                    sepo
                    Just for the record Podium can be faster than Kerky. It depends on presets you use. It is similar to 2 computers using same spec and one is faster than the other. It is all in fine tuning πŸ˜„
                      kwick7
                      Regards, Ross
                      All registered users- as in those that have purchased Podium already?
                      It would be nice to not have to load up Kerkythea and just render away in SketchUp. I have gotten better with Podium over the past 2 days, though, and will continue tinkering with it. The trial just isn't doing anything for me - too many limits.
                      At the price, though, I may just buy Podium- then I can see what the deal is with 1.5.
                      Now.... if only someone would port either of them to the mac- then I would be really happy. πŸ˜„
                        sepo
                        Mac porting is on our to do list.When I can not say though πŸ˜‰
                          kwick7
                          I'll take what I can get! Hope meter filled!
                          I long for the day when I can stop using bootcamp to render or I can stop using my old centrino pc laptop with a measily 512 megs of ram.
                          • spenceS Offline
                            spence
                            I like it Ross. I think you have done an excellent job. I'm trying to do the same with some of my models using Podium and I'm struggling. My model colors render all whack, I'm not doing so well with Podium. I want to do something like what you have done, Nice!
                            Spence
                              sepo
                              Spence visit us at forum. There will be someone keen to help.
