    Rendering software comparison
    65 Posts 17 Posters 12.9k Views 17 Watching
    • FrederikF Offline
      Frederik
      @sepo said:
      Hmmm.... I can show you scene where Podium will render many times faster than Kerky. It all depends on presets.
      😲 πŸ˜’ πŸ˜•
      I sure would like to see that, Sepo...
      With all due respect to the Podium plug-in, which IMHO is very intuitive, easy to use and well made... πŸ˜‰
      But as we both know, the render engine behind Podium is the Kerkythea SDK...!
      Regardless of whatever kind of tweaking and optimizations you can claim to have made, the engines are identical (apart from some exceptions available in KT and not in Podium...) and thereby I really can't see how you can claim that Podium will render many times faster than KT... πŸ˜•
      But if you want to give us (the KT Team) an example, I'm sure that we will be ready to give it a fair test... πŸ˜‰
      The render engine is only part of a great render, knowing how to use it is the other part.
      That's SO well said, Pete..!! πŸ˜„
      Cheers
      Kim Frederik
        sepo
        I will send you myscene.xml if you want and you render it and tell me the time πŸ˜„
          sepo
          lol ...OK bare with me... I will find suitable scene and we will give it a whirl. I will by you drink if Kerky renders it faster.
          I don't understand what do you mean by "And please also tell us how we can test it in Podium ourself..."
          • FrederikF Offline
            Frederik
            We're ready... πŸ˜‰
            And please also tell us how we can test it in Podium ourself... πŸ˜‰
            (That will also enable us to see what the output should look like...
            You can send the scene to frederik [at] kerkythea.net
            Cheers
            Kim Frederik
            • FrederikF Offline
              Frederik
              I'm not surprised... πŸ˜†
              First of all to get an idea about the render time in Podium ourself, and secondly to enable us to see what the output should look like... πŸ˜‰
              Cheers
              Kim Frederik
                sepo
                OK as you have better idea maybe you should organise the setup...πŸ˜„
                • StinkieS Offline
                  Stinkie
                  Oooh, a li'l contest.
                  We should really keep Sepo indoors. He just can't resist hassling the neighbours. πŸ˜„
                  I'm pretty curious about the outcome. But shouldn't the setup time count too? πŸ’š
                  • FletchF Offline
                    Fletch
                    Stinkie wrote: "I have tried KT at maxed out settings..."
                    Well, this is the common mistake of new users with Kerkythea (mine too! πŸ˜‰ ) ... people think (quite naturally) "higher settings must be 'better'" When in actuality it is important to understand what all those settings mean. And if one does not, then they are better off sticking to the 'presets' as their aid/friend/guide.
                    I have done many, many... and yes - many - test renders with various methods and settings in VIZ scanline, VIZ radiosity, Mental Ray, Vue Infinite 5 and 6, and Kerkythea. I can tell you Kerkythea gives me the best quality with fastest set up and ease of use/material mapping & creation... and I have gotten just as good results in 30mins at 2800px on PM+FG low preset in KT as I got in 24hrs with MLT... it ALL DEPENDS ON THE SCENE AND THE LIGHTING AND MATERIALS.
                    The key is knowing the 'optimum' settings... a professional workflow is to do test renders small and very low qual. settings, and slowly work your way to bigger renders/higher quality until you know what the settings will do without needing so many test renders.
                    Comparing speed of Kerkythea and Podium is both silly and pointless IMHO. Podium IS USING Kerkythea, but since it is inside SU is obviously much easier and quicker to use... TBD has done a good job 'optimizing' the settings for you, so you don't have to do all the testing/trials to actually learn the program yourself... you just get the fun of rendering. πŸ˜„
                    If Podium makes you and your clients happy, and you're having fun - well THAT'S WHAT MATTERS!
                    If you want to have choice to render the exact same scene with biased or unbiased methods, hundreds of advanced options, and soon to be much much more... then perhaps keep Kerkythea handy... but really, they serve two different 'audiences'. Podium is for people who want to just stick with SU and not have to "go-back-and-forth" and who do not want to have to think about all the other info available in Kerkythea.
                    Trying to compare them is, again, IMHO, both pointless and silly.
                    1-they both have the same engine - KT πŸ˜‰
                    2-you would have to make sure every single setting is the same in both of them... which you cannot be sure of πŸ˜’
                    3-what's the point? oh yeah, being happy rendering... and you can be happy with either of them! πŸ˜„ there's your answer... they both win.
                    Love, Fletch!
                    Fletch
                    • StinkieS Offline
                      Stinkie
                      Thanks for the explanation, Fletch. I did think "higher is better". Anyway, I also did it out of curiosity ("will my Mac Pro catch fire?"). By now, I've tried some of the presets - those work dandy. Fast, yes.
                      "If Podium makes you and your clients happy, and you're having fun - well THAT'S WHAT MATTERS!"
                      I'll slurp coffee to that!
                      "Trying to compare them is, again, IMHO, both pointless and silly. "
                      Valid point. But I think Sepo and Frederik both are smart enough to know that - them youngsters just wanna have some fun. πŸ’š
                      • FrederikF Offline
                        Frederik
                        To no-ones surprise, I happen to agree with Fletch... πŸ˜„
                        The point I wanted to make was that this can't be true, since the engine behind Podium is Kerkythea...!! πŸ˜‰
                        I have high respect for the Podium plug-in, but that's only when it comes to the way TBD have made it... The ease of use, where anybody can make a nice photo realistic render, without knowing anything about renders at all...
                        On the other hand, I can show many renders made in Kerkythea, which can't be achieved in Podium... Reason for this being that KT have so many much more advanced settings and options, which can't be made with Podium because of the limitations made to make it much easier to use... πŸ˜‰
                        Doesn't this conflict with your first statement (the one shown above..)..?? πŸ˜•
                        You said that you can show a scene, and now you want me to arrange the set-up..??
                        I can show you some renders made with KT, which you can't achieve in Podium, but what's the point really...??
                        Cheers
                        Kim Frederik
                        • soloS Offline
                          Good reply Fletch!
                          IMO the best render app is the one you enjoy and can use with ease and understanding.
                          Both Podium and KT are based on the same engine so the face off is pointless...if anything wait for Podium version 2 as it will not be KT based.
                          Happy rendering
                          • StinkieS Offline
                            Stinkie
                            Shall we postpone then?
                            Although it wouldn't be much more than some fun, it would be nice to see Podium 2.0 go up against KT Echo.
                            • FletchF Offline
                              Fletch
                              @solo said:
                              Good reply Fletch!
                              thanks, Solo πŸ˜‰
                              @solo said:
                              ...wait for Podium version 2 as it will not be KT based.
                              are you absolutely certain about that?
                              Postpone comparing KT to KT? I have thousands of renders comparing KT to KT if you want to see them, let me know... I can post some πŸ˜„
                              Fletch
                                guite
                                Glad to see that KT has a dedicated, jealous team. Its the only render app I have touched since 3d Studio (which version was that...?), now 3ds MAX.
                                Guite
                                • FrederikF Offline
                                  Frederik
                                  Not sure I get the point here... πŸ˜•
                                  We have just been pointing out the fact that the engine behind Podium is Kerkythea... πŸ˜‰
                                  So what's there to be jealous about..?? πŸ˜†
                                  Cheers
                                  Kim Frederik
                                  • FrederikF Offline
                                    Frederik
                                    Very interesting info indeed...
                                    And you're absolutely sure about this..??
                                    What will be the successor..??
                                    Cheers
                                    Kim Frederik
                                    • StinkieS Offline
                                      Stinkie
                                      That is shrouded in thick layers of mistery. πŸ˜„
                                      • soloS Offline
                                        I am absolutely sure, but being more of a 'Bahaman' I let the dogs out and not the cats. πŸ’š
                                          guite
                                          Frederik,
                                          I don't mean to rub you the wrong way (or any which way for that matter πŸ˜„ ). I had struggled to find the right word for what I wanted to say.
                                          I had used the word "jealous" as an expression of possesiveness, as in a jealous girlfriend or as in the third definition in Merriam Webster dictionary:
                                          3: vigilant in guarding a possession <new colonies were jealous of their new independence β€” Scott Buchanan>
                                          Guite
                                            I also guessed you were uing the word in some similar sense... like "anxiously protective". But then I1m not a native speaker so sometimes I also have problems with "fine tuning" the expressions I use... πŸ˜’
                                            • 2 / 4
