    Green Toaster's Car Sketches
    745 Posts 45 Posters 184.4k Views 45 Watching
    • soloS Offline
      That rock crawler...um...Rocks!!
        GreenToaster
        Thanks for the kind comments.
        I'd really like to finish this but there are so many other things I have to do today . . . maybe I can finish it Monday - I'm off on Monday because of MLK holiday.
        If you really want something you won't ever stop pursuing it.
          GreenToaster
          . . . today's car for the day . . .
            GreenToaster
            . . . took the notebook with me & as wifey went shopping, I sat in the car and created another blah, blah, blah . . .
            • ely862meE Offline
              ely862me
              i don t know what to say,to me isn t so hard here is my first concept car http://sketchup.google.com/3dwarehouse/details?mid=c08810ef646e17596bc31dd4cacd32eb and this is my before last concept car http://sketchup.google.com/3dwarehouse/details?mid=662484398c0f9ea712d7dab77a6f289
              Elisei (sketchupper)
              Come and See EliseiDesign
                GreenToaster
                WOW!
                Did you do both of those using only SketchUp? Do you have any suggestions - a description of your workflow, perhaps?
                Amazing cars - thanks for posting.
                  GreenToaster
                  . . . I'm taking a hiatus from this thread. After seeing ely862me's cars & others, I realize I'm stuck and I'm not making any significant progress - I'm not getting where I eventually want to be.
                  Of course, I'm certainly not giving up - I'm going to figure out how to create the really cool stuff - just takes some folks longer than others, I guess.
                  We all need a good kick in the pants every once in a while - I got mine. Ouch!
                  πŸ˜„
                  • CraigDC Offline
                    CraigD
                    Hey GT! Did you end up buying the book "How to Draw Cars Like a Pro"? It was a MonsterZero recommendation, so I went out and bought it!
                    IT'S AWESOME! Get it! I think it will give you some really good inspiration!
                    Model well!! πŸ˜„
                    Cheers,
                     - CraigD
                    Google SketchUp
                    • ely862meE Offline
                      ely862me
                      people i told u for me (and i don t know why but i like it) is verry simple (almost),all concepts that i have are mine(except the concept e002 wich is a modified bugatti veyron) and is no import and are build up in sketchup i can t make a tutorial because i make them in different and manny ways depends from what i start
                        GreenToaster
                        Yes! I got it from Amazon and yes, I like the book, it's very good - inspirational.
                        You can't just stop now...?
                        Ha! I'll post again - I just want to have something new - something fresh & different to offer. I'm a bit frustrated getting to the next level - for me, with my limited skills and "dang-near-zero" creativity, it's quite challenging getting there.
                        This journey began a few days ago as I started poking around the menus and there are several tools I've never used - perhaps that's obvious from my cars. I also realize - as others have mentioned - there are other s/w programs out there that are probably better suited for drawing amorphic shapes like body parts for cars. I'd still like to find out how far I can go with SU - looks like there will be lots of enjoyment as I continue.
                        most important is to watch the wireframes to see how are done
                        for having good proportions u can use temporary the position of the weels of a desired form of car
                        This is great advice - thanks, I'll investigate this more and try it - I'm sure this will be useful - will help me figure this stuff out. πŸ˜„
                          GreenToaster
                          Well - here's one point where I'm "stuck". The attached file contains a wireframe for a body part - like a hood, for example. I have no clue how to turn this into a nice, good looking surface. When I use the From Contours tool the surface ends up with weird, pointed areas that I don't understand. I'm sure someone could take this handful of curves and turn it into something "beautiful" - but how?
                          Thanks a whole bunch,
                          GT
                          bw_hood_wireframe_01.skp
                            GreenToaster
                            . . . here's almost an exact same wireframe model with a surface added using Concepts Unlimited . . . I have no idea how to do this with SU. :clueless:
                              GreenToaster
                              Thanks for the suggestion - I tried it but it's substantially different from the original wireframe model and the model I did using another program which has a flat surface on top with variable radius tangent arcs or conics bordering a perimeter of different sized ellipses.
                              I can keep working with it - I'm not used to modeling this way - with these tools. This is not a complaint, but just an observation that it looks like I'm going to have to (1) learn what SU can do, then (2) model what I want rather than modeling with a limited understanding of how to get the job done.
                              • CraigDC Offline
                                CraigD
                                A quick tip GT, that you probably already know... but when you select the Circle tool, you can type in the VCB (Value Control Box) and hit Enter, to add a higher number of edges that make up the circumference of the circle. This will give you a smoother curve to work with in your geometry.
                                Cheers,
                                - CraigD
                                Google SketchUp
                                  GreenToaster
                                  Thanks Craig - when I begin some serious modeling I'll work with changing that value. I've tried it before and it works great - like when I intersected two stretched spheres and removed material - higher number = smoother edges at trim line = higher regeneration time.
                                  BTW - I used to ride SV-650, CBR900RR, GSF-400, Ducati 900SS, plus 38 others. After my last two crashes I gave it up completely. I'll always want another bike. (snif)
                                  Brad
                                    GreenToaster
                                    depending how much wire u want to use u can make different qualityes, here a use medium quality
                                    So, did you use the Sandbox --> From Contours tool, or what? I don't remember seeing a means of adjusting the quality - is this done before the surface is created - when the arcs were created?
                                    Sorry to be so clueless - thanks for the help.
                                    • ely862meE Offline
                                      ely862me
                                      i didn t use the sandbox i use the hand
                                      i alway do this i fit them with hand the sanbox isn t precise
                                      i said medium quality because i wasn t use too many lines how do u expect to sandbox made a nice hood i use sandbox only for two lines two arches or something like that(i was using sandbox for the windows of my concept cars)
                                      • ely862meE Offline
                                        ely862me
                                        depending how much wire u want to use u can make different qualityes, here i use medium qualitybw_hood_wireframe_01[5].jpg
                                        here are the wires
                                          GreenToaster
                                          Sorry, but I still don't understand how you get your surfaces in there and they render so smooth - looks like you converted the one I started with - I feel like I'm the dragon inside the shell - almost strong enough to break out of the egg and fly.
                                          • ely862meE Offline
                                            ely862me
                                            i didn t coverted i make it again,for makeing a desired surface u must have enough wire to fill exactly that form what u wish to do so u make a bigger arch on the bottom then one smaller then another smaller then another smaller when u gonna fit the wires is gonna be a nice rounded form smoth it and is gonna be exactly how u want to be
                                            • 37
                                            • 38
                                            • 3 / 38
