    Fun 'Little' Project
    14 Posts 8 Posters 976 Views 8 Watching
      tomsdesk
      ...proposal (freebee) to do a proposal for a fundraising concept proposal:
      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA4-WC.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA4-WC2.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA4-WC4.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA4-WC4dtl.jpg
      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA4-WC2dtl.jpg
      2.5D Trees & Shrubs!
      • marked001M Offline
        marked001
        wow! is all i have to say..these are awesome, tom. i love the slight slight transparency...i've tried this before and have never really been terribly successful...these are great though.
        http://www.revision21vis.com
        instagram: revi21on
          tomsdesk
          Thanks Jason...me too before with same questionable results (just can't quite get the Bajan to work for me), but since this one will likely die before fleshing it out entirely I tried again hoping to give the flat color areas some interest. Glad to hear I'm not the only one here to think it worked a bit.
          The architect is happy, but not as willing as I to throw a bunch more free time into the project...so I may be finishing the design details for myself if it dies at this stage (and a pity it will be as he is a wonder!)
          • boofredlayB Offline
            boofredlay
            Tom, your images are always pleasing to the eye. This is great work. Thanks.
            • spenceS Offline
              spence
              Tom,
              I really like the colors you have used, they are softer and not so overbearing. These look great!
              Spence
                marked001
                haha...i'll be totally honest and say that i am not always a fan of the bright bright colors you use Wink otherwise, they're beautiful...i guess i have sensitive eyes. cant wait to see if this progresses..
                instagram: revi21on
                  tomsdesk
                  ...you mean like this? (my trees still need a bit of a bland applied in SU):
                  http://www.sketchucation.com/forums/scf/sas/Gallery/tn_bert1-wc.jpg
                  http://www.sketchucation.com/forums/scf/sas/Gallery/tn_bert1-wcdtl1.jpg
                  http://www.sketchucation.com/forums/scf/sas/Gallery/tn_bert1-wcdtl2.jpg
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thanks Tom, I enjoyed viewing. The sky in the
                    second pic is spot on.
                    Mike
                      tomsdesk
                      Added a sculpture to the fountain (anybody seeing the wharf theme :`). The water didn't work out too well...I'm thinking some texture on the wall behind is needed to give the filters something to interact with. Any other hints to DWC work it better?
                      http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA5-WC.jpg
                        marked001
                        maybe export the background minus the water and then the water on its own and adjust the transparency in pshop?
                        instagram: revi21on
                          tomsdesk
                          A bit more colorful, but still muted...enough? (Those windows are sure reflecting some wishful thinking, huh?, I will fix that :`) The fountain looks better to me, but I'm gonna try unhiding some of the edges...painting some dark some "white" for highlights.
                          But first I gotta finish this as-built of a little house...worse field measure job by an architect I've ever seen! (The client lady's dims close better than his...?) Talk about wishin' Friday was over with!
                          http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA5-tom-WC.jpg
                            todamgood4U
                            Tom, I have to agree with Jason, I too wasn't much of a fan of the bright colors, but you nailed this one! I even went back and took a second look at all the images...very, very well done. Contrast and tone are wonderful and very pleasing to the eye.
                            Great job!!
                              tomsdesk
                              Okay, beat this image up pretty good...thanks for the interest and advice! I did a little better with the water I think (still a long way to go...bunches :`) but I'm pleased with something else I tried: Ross' cut out and add at the windows, but instead of using a blend underpainting thingy I used stretched pieces of the same sky background.
                              Whadaya think?
                              http://www.sketchucation.com/forums/scf/sas/Gallery/tn_NHCA5-tom-WC3a.jpg
                                Bill Wilson
                                πŸ˜„ You're a great artist Tom, the colours are very easy on the eye. It looks like a very large project, can you tell us more about it? At first glance your 'wharf theme' with the fountain looks a bit like a sewage outlet marker bouy with bell πŸ’š Then again you may have a different system of beacon and bouyage in your neck of the woods. The degree of list on it shows that there is a fairly strong current in that area. Can you tell us where it will be situated if approved? Thanks for sharing Tom, I think this is the place to be to see different achitecturel ideas from other parts of the globe.
                                Thanks Tom,
                                Bill.
