    Rendering software comparison
    65 Posts 17 Posters 15.8k Views 17 Watching
    • EdsonE
      Edson
      congrats for your initiative. it is always good to have this kind of comparison.
      may i suggest you do not forget to test artlantis?
      http://www.mahfuz.arq.br
      • StinkieS
        Stinkie
        A good initiative. The difference in render time is obviously due to the fact the current version of Podium uses only one core. My gut tells me this'll change.
        • jenujacobJ
          jenujacob
          comparing render engines are very hard actually...
          unless u have a set of rules where u can define as to what all features u would like to test i think its kinda fruitless...
          i mean take KT for example.. the above render is using pm+Fg.. (biased render)which gives out completely different results from the unbiased render options like MLT or BiPT or PPT...
          Podium i think has only unbiased redner solutions.. so its fine in that aspect here...
          but when u compare Maxwell or fry render.. they only deal with unbiased rendering... so thats a different benchmark all together...
          Vray on the other hand has a mix of both biased and unbiased rendering algorithms...
          U could on the other hand... try to compare the render engines on the basis of these :-
          1. based on one touch render solution... without any manipulation of materials in the external render engine..
          2. set up time...
            3)ease of use....
            4)speed... which u have mentioned here..
          i hope i am clear in what i am tryin to explain here... not to step on anyones shoes here..
          kwistenbiebel can talk more bout it here.. hes an expert on all things rendering!!! πŸ˜„
          • StinkieS
            Stinkie
            Valid points, Jenujacob. I must add, however, that since 1.5 Podium also uses MLT.
            • soloS
              I have seen crappy Max renders, brilliant Indigo renders...etc.
              The render engine is only part of a great render, knowing how to use it is the other part.
              I also agree Kwistenbiebel would be the best person to make comparisons, however I see no conclusion arising from it, just like diets cannot be compared as the only one that works is the one you keep to, render engines are the same as the best renders come from understanding, learning and talent.
              The top comparison reeks of bias as the wasted time for export and GUI maneuvering in KT was not mentioned, or the conditions used.
              • StinkieS
                Stinkie
                Let's also not forget: different tools for different jobs. In my opinion, unbiased yields the best results. However, unbiased renderers seem somewhat unpractical to use in a production environment. Unless, of course, you own a whole fleet of 'manycores'.
                Oh yeah: the price counts too, obviously.
                • StinkieS
                  Stinkie
                  Sorry, my bad. Or actually Bigstick's. Search the Podium forum, you'll see. πŸ˜„
                  Your point about comparing apples and pears seems valid to me. To some extent these kind of comparisons seems to derive from the need to find the 'ultimate renderer' -a thing that does not exist. πŸ˜„
                  • K
                    kwistenbiebel
                    That would be my conclusion as well πŸ˜„
                    ...It all depends on the kind of scene you want to see rendered.
                    What seems to be the ultimate render engine for scene A, is often the worst solution for scene B and vice versa.
                    • K
                      kwistenbiebel
                      Correction Stinkie,
                      Podium doesn't support MLT (Metropolitan Light Transport), but it does support PT (Path Tracing). Both are unbiased methods. MLT is effective on scenes with a lot of indirect light, while PT is master in scenes that contain a lot of direct lit objects (e.g sun lit exteriors).
                      @Jenujacob,
                      Indeed I like to play with different render engines, although that doesn't make me a master. πŸ˜‰
                      @Rob D,
                      As Jenujacob and Solo pointed out, comparisons are difficult to do correctly.
                      In fact, I tried it before , but in the end, I found out that in some way, the comparison always fails as each render engine uses a different approach (on materials, physical sky,camera,tonemapping, etc..), making it comparing apples and pears.
                      Instead, I like to render a particular scene using different render apps, and just post the results for all to see, together with some info on the settings used (render time etc...).
                      I have posted gallery threads like that earlier on sketchucation gallery section (the old forum), but I stopped doing that because the scenes contained too much geometry (.3ds imports) that wasn't native Sketchup.
                      • StinkieS
                        Stinkie
                        On the positive side, a side by side comparison could help people to decide what renderer they might get for different tasks.
                        Also, it might shed at least some light on what your getting for your buck (prices matter!). Visiting the respective forums would of course be a must.
                          Rob D
                          Thanks everyone for the tips. I'll try to incorporate your views so please keep 'em coming!
                          For me, the useful thing would be to have a benchmark for a "passable" render on several different programs. The majority of us just want to stick our SU model into a renderer, tweak a few materials, hit "render", and get something a little more realistic than SU output. So we might as well have that as the benchmark. Anything more than that starts to become a test of the users skill level, rather than the software, as a few of you have said.
                            sepo
                            Hmmm.... I can show you scene where Podium will render many times faster than Kerky. It all depends on presets.
                            • StinkieS
                              Stinkie
                              I haven't made any comparative renders, but I have tried KT at maxed out settings on my octo core. Took all night for the render to get at about 40%. Obviously this is in part due to my limited experience with the app (which in itself looks cool), but I was nevertheless a tad surprised.
                              • FrederikF
                                Frederik
                                😲 πŸ˜’ πŸ˜•
                                I sure would like to see that, Sepo...
                                With all due respect to the Podium plug-in, which IMHO is very intuitive, easy to use and well made... πŸ˜‰
                                But as we both know, the render engine behind Podium is the Kerkythea SDK...!
                                Regardless of whatever kind of tweaking and optimizations you can claim to have made, the engines are identical (apart from some exceptions available in KT and not in Podium...) and thereby I really can't see how you can claim that Podium will render many times faster than KT... πŸ˜•
                                But if you want to give us (the KT Team) an example, I'm sure that we will be ready to give it a fair test... πŸ˜‰
                                That's SO well said, Pete..!! πŸ˜„
                                Cheers
                                Kim Frederik
                                  sepo
                                  I will send you myscene.xml if you want and you render it and tell me the time πŸ˜„
                                    sepo
                                    lol ...OK bare with me... I will find suitable scene and we will give it a whirl. I will by you drink if Kerky renders it faster.
                                    I don't understand what do you mean by "And please also tell us how we can test it in Podium ourself..."
                                    • FrederikF
                                      Frederik
                                      We're ready... πŸ˜‰
                                      And please also tell us how we can test it in Podium ourself... πŸ˜‰
                                      (That will also enable us to see what the output should look like...
                                      You can send the scene to frederik [at] kerkythea.net
                                      Cheers
                                      Kim Frederik
                                      • FrederikF
                                        Frederik
                                        I'm not surprised... πŸ˜†
                                        First of all to get an idea about the render time in Podium ourself, and secondly to enable us to see what the output should look like... πŸ˜‰
                                        Cheers
                                        Kim Frederik
                                          sepo
                                          OK as you have better idea maybe you should organise the setup...πŸ˜„
                                          • StinkieS
                                            Stinkie
                                            Oooh, a li'l contest.
                                            We should really keep Sepo indoors. He just can't resist hassling the neighbours. πŸ˜„
                                            I'm pretty curious about the outcome. But shouldn't the setup time count too? πŸ’š
                                            • 1 / 4
