    Visualisation SU+Maxwell+Pshop
    28 Posts 16 Posters 4.8k Views 16 Watching
      sepo
      Rob that would be great. I look forward 😄
      ypnos1 try these trees
      Full Decidious
      (www.howardmodels.com)
      MODERATOR'S EDIT: The images at this link are commercial and almost certainly copyrighted.
      • W Offline
        Will03
        I love that link! I wonder, are we allowed to use these commercially though?
          dylan
          A nice set of trees!
          What do you find is the best way to remove the white background?
          http://dmdarchitecture.co.uk/
          • W Offline
            Will03
            If you're on photoshop,
            select > color range
            I found a value around the 70's seemed to work pretty well.
              sepo
              Try Alphaworks plugin from this site http://www.cybia.co.uk/alphaworks.htm
                mateo soletic
                There is a tutorial somewhere...
                here it is. http://www.axialis.com/tutorials/tutorial-misc001.html
                [Concept Illustrations](http://concept-illustrations.com/)
                  kwistenbiebel
                  Thanks for those links. that's great stuff.
                  It would be great if there was a special 'post process' section in the gallery forum.
                  Cheers,
                  Kwistenbiebel
                  • jujuJ Offline
                    juju
                    We've started a Post Processing section in the tutorial section, is this what you had in mind? I know it is a bit thin at the moment, but it will grow as time goes by and people post some tutorials.
                      kwistenbiebel
                      That's great Juju. IMHO the post tonemapping of the render output is primordial.
                      Sometimes bad renderings can be 'saved' by using the right Pshop tricks.
                      Alternatively, sometimes bad pshopping screws up a rendering that basically was pretty good to start from. 😆
                      Looking forward to see some good tuts in that new section.
                        Jackson
                        Those tree images in that link are commercial and almost certainly copyrighted- although the guys's been a bit foolish posting such large previews (and no legal notices!), but nevertheless using them would surely be a breach of copyright. I edited the post with a note to this effect. As usual, if it seems to be too good to be true....
                        Jackson
                        Jackson
                        • 2 / 2
