    Solved: need help with groups and their names
    6 Posts 2 Posters 895 Views 2 Watching
      a4chitect
      hello rubies, is there a way to select groups by their name?
      i want to be able to access the position of a specific group in the model and only know its name
      thanks
      (do you think that selecting all groups and checking each one in a loop is as good as it gets?)
        a4chitect
        found the solution myself, thanks for watching
        Sketchup.active_model.active_entities.find_all {|e| e.name=="Group Name"}
        • fredo6F
          You should check the type too (e.type == 'Group') as there may be other drawing elements with the same name
            a4chitect
            fredo please go into more detail, because this combination doesn't find the group
            Sketchup.active_model.active_entities.find_all {|e| e.class=="Sketchup;;Group" and e.name=="Group Name"}
            • fredo6F
              Sorry, I meant e.typename == 'Group'
              If you prefer to use class id, then you must NOT enclose it between quotes
              --> e.class == Sketchup::Group
                a4chitect
                fantastic - thanks!!!
                i guess that going through the basics of ruby in SU is inevitable, but doing mash-ups is so much fun πŸ˜„
