    Contour generation from ruby script
    2 Posts 2 Posters 770 Views 2 Watching
      ARUNKUMAR
      Hello Friends,
      I'am new user of SU Pro (ver 6).
      Now am trying to check cloud ruby script with my existing data file which is in txt format. I'am able to see a message at the bottom left of my screen as "2045 points to import" after providing required info in "Points Cloud Option" dialog box but nothing is created on screen.
      I'am using a space delimited file. Is there any restriction with no. of input points.....please suggest.
      Arun Kumar
        Arun, this is the depository, please, do not discuss rubies here.
        The discussion about this script is already here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=127&p=19449#p19449
        Didier has just updated his script.
        Did you make sure that you use the latest release? (The old cloud.rb does not work with SU6).
        I'm moving this thread now to the general ruby discussion forums but also lock it at the same time so there won't be two threads on the same topic (and Didier does not need to answer in several places to the same questions).
        I do really hope you don't mind this.
        Also, please read the announcement about the new board (and startin new topics here).
        BTW - Didier, could you register there? I want to move your scripts to the new place!
        πŸ˜„
