    Sunflow exporter update
    10 Posts 6 Posters 13.1k Views 6 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I've uploaded an update of my Sunflow exporter.
      Supports 2 UI modes, camera types, background, render and gobal illumination settings, lights, save/load parameters within SKP.
      Can be found here
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1515 and on my site as well.
      Regards,
      DB
        alexander
        thanx Didier.
        keep them coming..
          Ross Macintosh
          I thought I'd add a link to the SunFlow site...
          http://sunflow.sourceforge.net/
          Check out the Gallery!
          For those unfamiliar with it, Sunflow is a free rendering system. Because it is java-based it can be used by windows users, mac users, and linux users. It supports multithreading so you can put those new multiple-core procesors to work.
          Here is the SunFlow FAQ's: http://home.comcast.net/~gamma-ray/sf/sunflow-faq.htm
          Note that it gives instructions on how to make a shortcut to open the application from your desktop.
          Also be sure to see Didier's instructions found in his download.
          Thanks Didier for your generous work to make this renderer an option for the sketchup community.
          Regards, Ross (Didier Fan) 😄
            Ross Macintosh
            In the following thread in the Render Gallery I have posted some experiments using Didier's script + SunFlow...
            301 Moved Permanently
            (www.sketchucation.com)
            Regards, Ross
            • AdamBA Offline
              AdamB
              Been having a blast with Sunflow. It is very sad the developers put so little effort into helping getting started / docs but hey, I haven't had as much fun since playing with Renderman when it first came out.
              Not sure how I fold changes into the exporter, so I'll post the diff changes to "su2sf.rb" here to support textures and UVs
              629c629,638
              <     @stream.print "\n\tuvs none" # TODO fix uv mapping
              > #    @stream.print "\n\tuvs none" # TODO fix uv mapping
              > # AMB added
              >     @stream.print "\n\tuvs vertex"
              >     meshes.each do |m|
              >       m.uvs(1).each do |p|
              >         @stream.print "\n\t\t#{PRECISION % (p.x)} #{PRECISION % (p.y)}"
              >       end
              >     end
              680c689,710
              <         else
              > # AMB added
              >         elsif mat.texture
              >                       # check which extension it is
              >                       filepath = File.dirname(mat.texture.filename) + "/"
              >                       filename = File.basename(mat.texture.filename)
              >                       filename = filename.split(".")[0] if filename.split(".").length > 1
              >                       [".jpg",".png",".tif",".bmp",".gif",".tga"].each do |ext|
              >                               testfile = filepath + filename + ext
              >                               if File.exists?(testfile)
              >                         @stream.print "shader {",
              >                           "\n\tname \"#{name}\"",
              >                           "\n\ttype diffuse",
              >                           "\n\ttexture \"#{testfile}\"",
              >                           "\n}\n\n"
              >                         return name
              >                               end
              >                       end
              >          else
              Adam
              PS And here's a snapshot of a Sunflow rendering of Quake exported from Sketchup... because I can in case you ask!
              Ambient Occlusion and 1 Directional
                Ross Macintosh
                Hi Adam -- I'm not quite sure what I'm looking at in your posted image. It is great that you figured out support for SU textures & UV's. Hopefully Didier can add your code into the next version of the SU2SF script.
                My hope is that eventually we can use the plugin to define material attributes like shininess to specific SU materials without needing to rename those materials and edit the exported file as is now necessary.
                Regards, Ross
                • I Offline
                  ilay7k
                  Hello Adam, thank you for this...but
                  i have some errors with it:
                  D:/Program Files/gsu6/Plugins/su2sf.rb:1583: syntax error
                  Can you attach modif. script?
                  Thanks again
                  uh janino tree-shader nodes...uh
                  • tbdT Offline
                    tbd
                    Adam: bsp importer is done in Ruby ?
                    http://plugins.ro
                    • AdamBA Offline
                      AdamB
                      ilay7k: How did you apply the changes? I ask because line 1583 is way away from the small changes I did.. I've attached the version I have.. I'm just wary of having N versions of this exporter floating around - better Didier folds in these into his..
                      TBD: yes, ruby script to read quake (using BitStruct). Needed some test data to play with 😄
                      Adam
                      su2sf.rb
                      • I Offline
                        ilay7k
                        Thank you...
                        i use this - 28.08.07: Edited by D. Bur: v 1.1, added lights support, save/load parameters.
                        So i change string2string by Akelpad/i modify too, add some mats-syntax(old version of this forum had some my tests)
                        No way - SkipyMan - renderman connection...i prefer free solution like sf or aqsis..
