    Pre upgrade Podium works
    19 Posts 6 Posters 3.0k Views 6 Watching
    • soloS
      http://img405.imageshack.us/img405/9736/200708131711187m27stj3.jpg
      • soloS
        http://img513.imageshack.us/img513/2658/2007080118520140m44sop5.jpg
        http://img453.imageshack.us/img453/5770/200707261455372m59sxj8.jpg
        http://img523.imageshack.us/img523/4779/200707261601042m57syn5.jpg
          marne
          wow, they are fantastic!
          • soloS
            http://img267.imageshack.us/img267/9596/200705141suw9.jpg
            http://img530.imageshack.us/img530/7115/200705141233561h29m43sta9.jpg
            http://img530.imageshack.us/img530/606/citynights1vq0.jpg
            • soloS
              http://img530.imageshack.us/img530/5232/goodmorningrc0.jpg
              http://img453.imageshack.us/img453/5968/homesweetgnomesk6.jpg
              http://img530.imageshack.us/img530/9708/kitch2mj7.jpg
              • soloS
                http://img530.imageshack.us/img530/2002/watchedbz5.jpg
                http://img508.imageshack.us/img508/9180/200704020010021h41m53sst1.jpg
                http://img373.imageshack.us/img373/784/thefogcd6.jpg
                • K
                  kwistenbiebel
                  Nice collection Solo,
                  You are quite a productive and creative personality.
                  You also seem to be able to give your images that 'something more'.
                  Very refreshing and always interesting.
                  Solo, could you describe in a few words the best method to get a poser model in Sketchup?
                  (export and import methods to keep uv-mapping in place)
                  Cheers and thanks for sharing,
                  Kwistenbiebel
                  • soloS
                    http://img530.imageshack.us/img530/5454/bahamapictureff7.jpg
                    http://img530.imageshack.us/img530/1122/ometesttx1.jpg
                    • soloS
                      Biebel
                      Keeping textures on import is a hit and miss thing, In the Podium tips and tutorials, under modelling tips I have a few tips on how to import .3ds keeping the faces intact. Texture imports are more involved and require some strange manoeuvers that do not always work. I have never had success with Poser imported textures unless I import into Vue then export .3ds (however they normally are way too heavy for use in SU) I usually open model in Max and strip the textures, import into SU and reapply them (long way)
                      • boofredlayB
                        boofredlay
                        Great work as always Solo. Thanks for sharing.
                        • K
                          kwistenbiebel
                          Thanks solo for those tips on Poser imports in SU.
                          Is it true that Poser 5 is a better match for Sketchup as Poser 6 because the polycount of the models is lower?
                          Thanks,
                          Kwistenbiebel
                          • soloS
                            Poser 1-4 have low poly options that look like FF characters when imported, poser 5 and 6 have higher poly figures great for foreground placement. Poser 7 has way too many bugs to even bother with, install is too big and it takes ages to load, and it lags bad.
                            so in answering...it depends where you want the figure fore or backround.
                            A useful tip: if import is clothed then remove anatomy that is not visible, including tongue, teeth etc, as that reduces the size considerably.
