    Texture.use_alpha?
    6 Posts 3 Posters 1.3k Views 3 Watching
    • T
      tomasz
      Is there way to find out if a texture has alpha channel?
      Texture class has no such a method. Material method relates to transparency (opacity).
      Will material.materialType help me?
      Tomasz
      • tbdT
        tbd
        nope 😢
        nope again - it returns the same value as for a non-alpha texture
        you can look for 'tRNS' chunk inside .png files - if present than it contains transparency
        http://plugins.ro
        • tbdT
          tbd
          here some quick code to check for PNG transparency
          class ReadPNG
            def initialize(file)
              @pngfile = File.open(file,"rb+").read
              read_offset(8) #skip header
            def transparent?
              ok = true
              while ok
                chunk_size  = read_offset(4).unpack("N")[0]
                section     = read_offset(4)
                case section
                when 'PLTE'
                  read_offset(chunk_size)
                when 'IDAT'
                when 'tRNS'
                  return true
                else
                  @offset += chunk_size
                ok = section != "IEND"
                read_offset(4)  # skip CRC
              return false
            def read_offset(length = 1, offset = nil)
              @offset ||= 0
              @offset = offset if offset
              begin
                ret = @pngfile[@offset, length]
              rescue
                p "error reading at #{@offset}"
              @offset += length
              ret
          p ReadPNG.new('texture.png').transparent?
          http://plugins.ro
            azuby
            Put the file opening and read to the "transparent?" method. Because this way you 1. can close the file from within the instance when you're ready with analyse and 2. can react on changed png file.
            azuby
            *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
            Bad English? PM me, correct me. :smile:**
            • tbdT
              tbd
              azuby: true. thanks
              http://plugins.ro
              • T
                tomasz
                Hi TBD,
                I am surprised there is no such a method.
                The PNG testing will be helpful for me.
                Thank you!
                Tomasz
