    UI Messagebox within LMB method of a tool
    6 Posts 2 Posters 1.1k Views 2 Watching
      tomasz
      vI have no idea how to make messagebox 😒 displayed within create method of a tool.
      It is working but it is not visible. Sad I am afraid there is no solution.
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        tomasz
        I have found solution. I had to move UI.messagebox to draw method.
        If you display UI.messagebox in draw method it will be invoked twice
        if not suppressed earlier
        if displayed==false
        displayed=true #to prevent second execution of whole if-end section
        UI.messagebox "Hello world!"
        displayed=false
          todd burch
          The .draw method is called every time you execute the view.invalidate method. Therefore, you control when the screen gets updated.
          I know of no restrictions that UI.messagebox can only be placed in the .draw method. It can be placed anywhere. (I just tested it to confirm in both the onLeftButtonDown and initialize method).
          Todd
            tomasz
            Draw method is also executed when you open Messagebox within the method πŸ˜„.
            I have placed UI.mb in LMB method and it was not displayed. It was invisible but present, awaiting for user input. I cannot validate the view during UI.mb. Todd how have you achieved it? πŸ˜„
            I am still new to Tools methods so I could have done sth wrong.
            Tomasz
              todd burch
              Can you post your code? It works great for me in the onLButtonDown method, both before and after the view.invalidate call.
              Todd
              If you don't want to post, send it to my fullname, no spaces, to my mac dot com address.
                tomasz
                I have found it! Silly me. I have placed view.invalidate at the end of draw method 😳
                def draw(view)
                	if( @ip1.valid? )
                		if( @ip1.display? )
                			@ip1.draw(view)
                			@drawn = true
                	if( @ip2.valid? )
                		@ip2.draw(view) if( @ip2.display?)
                		self.draw_geometry(@ip1.position, @ip2.position, view)
                		view.invalidate #WRONG!
                		@drawn = true
                Each time UI.messagebox was invoked SU called draw method which erased MB from the view.
                Tomasz
