    Preparing for SmustardOrganizer script
    56 Posts 11 Posters 8.9k Views 11 Watching
    • jujuJ
      juju
      Rick, I'll have to run the organizer script every time I change (add / remove some) the ruby scripts right? I would assume so, just need to be clear on it.
      If so, I just add the scripts to the plugins folder and run the script again, that shouldn't have a negative effect on the scripts already "organized" right?
        RickW
        If you run OrganizerEdit on your scripts, then organize them in subfolders (one level deep only), they will all load whenever you start SketchUp, with submenu items according to their locations. If you rearrange them, then restart SketchUp, they will automatically load with new submenu items, because the submenus are created dynamically at load-time based on the subfolder name.
        If a script/plugin comes Organizer-ready, there's nothing to do - it will load when you load Sketchup, however you decide to organize it.
        If it's not Organizer-ready, you'd have to run OrganizerEdit to make it Organizer-compatible. That wouldn't affect the other scripts.
        You could, I suppose (haven't tried it yet), run Organizer manually when you downloaded a new script to bring it into the menu. It shouldn't duplicate menu items for previously-loaded scripts.
        Did I answer your question?
        RickW
        www.smustard.com
        • jujuJ
          juju
          Kind of, I suppose. Trial and error will tell...
            RickW
            There are two parts to Organizer. One part is OrganizerEdit, which will rewrite .rb files with a bit of code so that they can be placed in a subfolder and loaded to submenus corresponding to the subfolder. Once the file is edited, it can be moved to any subfolder and will load appropriately - you don't need to re-edit it to move it around.
            The second part is Organizer, which does three things: it reads the immediate subfolders of the Plugins folder, creates a submenu in the Plugins menu for each folder it finds (and that isn't in the "exclude" file), and creates a menu item in that submenu for each .rb file it finds in that subfolder. That's a bit over-simplified, but it gets the idea across.
            So, if you decide you want to move a .rb file from Plugins/Draw to Plugins/Modify, just move it. The next time you start SketchUp, that script will be in the Plugins>Modify menu without you having to do anything but move the file.
            RickW
            www.smustard.com
              RickW
              I've almost finished work on a tool to help make the best use of Organizer. It will traverse your plugins and determine which files need to be located directly in the "Plugins" folder (anything that is "required" by another plugin should be either in the "Plugins" folder or the "Tools" folder).
              This will solve about 99% of the problems some users have with Organizer (moving files that shouldn't be moved).
              This file will be included with the Organzier download.
              RickW
              www.smustard.com
              • BurkhardB
                Burkhard
                I remember the hard times to do such things manualy 😉
                http://www.ia-plus.de
                • jujuJ
                  juju
                  Rick, will revised version (-s) be available for free upgrade to existing script owners or not?
                    RickW
                    Generally, updates are free to previous customers. We haven't really had upgrades yet, but that will be up to the author. I expect upgrades would generally have a nominal upgrade fee.
                    The tool I mentioned above will be part of an update, so it will be free to existing Organizer license owners.
                    RickW
                    www.smustard.com
                    • jujuJ
                      juju
                      Sweet, so I'll get an e-mail then notifying me just as I got an e-mail the other day asking for feedback.
                        RickW
                        I can do that. But the best way to stay informed is to "subscribe" - RSS and Atom feeds are available. 😄
                        There are several readers and subscription managers out there (reader.google.com, http://www.bloglines.com, others), and you can get updates and news about the latest scripts delivered directly.
                        I've been thinking about an automatic email notifier, but haven't implemented it yet...
                        RickW
                        www.smustard.com
                        • jujuJ
                          juju
                          I've already got Smustard on my RSS feeds... 😉
                            RickW
                            Cool! Then you're all set 😄
                            RickW
                            www.smustard.com
                            • H
                              Haggai
                              Hi Rick,
                              I got the organizer and install many of my scripts there in different folder, it seems that many of the file did not get change but i will still look thru all of them, i already saw some that are not but they are neither in the log file.
                              another thing that i am getting is this message and I don't know what to do with it,
                              "Error Loading File organizer.rb
                              undefined method `add_item' for nil:NilClass"
                              thank you for your help there.
                              [haggai]
                              • H
                                Haggai
                                Rick, another thing my "select at startup" is not funtioning anymore i downloade the last version but it still not selecting, does it go in another place than the plugins folder?
                                [haggai]
                                  RickW
                                  Not all files will be edited - only those that have a menu item in the Plugins menu will be edited. They can still be put in subfolders, but will appear in their specified menu locations.
                                  SelectAtStartup (startup.rb) should be located in the Plugins folder, not in a subfolder.
                                  Make sure you don't have sketchup.rb, langhandler.rb, or oImage.rb in your Plugins folder.
                                  RickW
                                  www.smustard.com
                                  • H
                                    Haggai
                                    I don't have these files in my plugings folder, they are in the "tools" folder.
                                    Can I edit the other file manualy to have them be "organizer.rb friendly"?
                                    if yes what do I need to change?
                                    I still don't know what is the message
                                    is there things I need to do, I read all the infos about how to install bout ten times, i think that i did it ok and it work for many of the rubys, I don't mind if they do not all get organized now but the message is in the way.
                                    thank you
                                    [haggai]
                                      RickW
                                      Open the ruby console (Window>Ruby Console) and type
                                      load "organizer.rb"
                                      then press <enter>. If the error message displays, copy and paste it into a message - make sure to copy everything in the console.
                                      RickW
                                      www.smustard.com
                                      • H
                                        Haggai
                                        OK thank you, i did as you said and locate the error message, it came from a french stair ruby i removed it and now i don't get the message anymore.
                                        this was the error line when a run ( load "organizer.rb" )
                                        Error: #<NoMethodError: C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:210: undefined method `add_item' for nil:NilClass>
                                        haggai
                                        here is the ruby file that i removed what shall I do to it to function
                                        http://www.sketchucation.com/forums/scf/sas/Ruby/fr_stair_maker062.rb
                                        • H
                                          Haggai
                                          The file is missing information for creating menu items. I downloaded it from Didier's website, and it is non-functional in both the French (which you posted) and English (which I downloaded) versions.
                                          I fixed the file (attached below), and it should now work.
                                          404 Not Found
                                          (www.sketchucation.com)
                                          • H
                                            Haggai
                                            Rick,thank you for looking into this for me, I put the file yuo sent to the pluggings folder and it function ( but the script in imperial and not metric ).
                                            the other thing is that if I put it in my "French" subfolder it still gives me the same error message
                                            I give you the error message plus few lines above concerning the same script
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:179: warning: (...) interpreted as grouped expression
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:195: warning: (...) interpreted as grouped expression
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:288: warning: (...) interpreted as grouped expression
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:304: warning: (...) interpreted as grouped expression
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:29: warning: method redefined; discarding old archetypesElements_straightConcreteStair
                                            C:/Program Files/Google/Google SketchUp 6/Plugins/10 French/fr_stair_maker062.rb:131: warning: method redefined; discarding old archetypesElements_straightSteelStair
                                            thank you very much for helping
                                            for my other files it seems that the first time I ran the organizer.rb it did not take everything but now I bring many of the file back to the pluggins folder run the script and put them back after. I think that it should be different but this way now I see what is happening, but for the future will I have to put my scripts first in the pluggins folder and then move them to subfolder or can I put them straight in the subfolder??
                                            I am sorry for taking so much of your time but hopefully my questions will help others like me.
                                            haggai
                                            http://www.sketchucation.com/forums/scf/sas/Ruby/load error.png
                                            • 2 / 3
