    Female figure on curved up background (not suited for work)
    35 Posts 14 Posters 14.3k Views 14 Watching
      Ross Macintosh
      Beautiful renderings. Are you sure you even used a renderer? Okay, I'll accept they are renderings because chances are you aren't that good of a photographer. 😉
      Excellent.
        kwistenbiebel
        Thank you Ross. 😄
        The first 2 images are Fry renders.
        The last one (black and white) was made in Podium.
        The woman figure is a .3ds model imported in SU.
        Cheers,
        Kwistenbiebel
          Just don't go wild Biebel!
          Nice renderings anyway.
            kwistenbiebel
            Ah some subtle nudity....I hope the internet isn't entering some Victorian age.
            A naked body is just a beautiful thing.
            I have no intention in making it pornographic in any way...
            although I have a good pornographic memory...or was that a photographic memory......with me it kind of relates to the same thing I'm afraid 😄
              I didn't mean to be "Victorian" - was just joking... 😛
              And yes, the renders are indeed nice.
              • E Offline
                ehaflett
                Awesome work, Biebel, I'm dumbfounded.
                Did these renders motivate anyone else to readTHIS POST ?
                • boofredlayB Offline
                  boofredlay
                  Eric... Booooooo
                    mateo soletic
                    Where is that 3ds model ?? 😆
                    By the way nice work.
                    [Concept Illustrations](http://concept-illustrations.com/)
                    • FrederikF Offline
                      Frederik
                      What a nice model, Chris! 😄
                      You're a true artist... 😉
                      Cheers
                      Kim Frederik
                        kwistenbiebel
                        Thanks! 😄
                        ...And the last one of the series.
                        The image is meant to emphasize on the beauty of the female body and not to be disrespectful. if people would find this last image to be offensive I'll kindly remove it. (I hope not though).
                        Cheers and thanks for watching,
                        Kwistenbiebel
                        RAW Fryrender output:
                        http://omploader.org/vN2dz/skin-on-pink-small.jpg
                        • soloS Offline
                          It was just a matter of time...LOL
                          She has a pet.
                            kwistenbiebel
                            It's merely a shadow 😉
                            • N Offline
                              nomeradona
                              christ,
                              the viewpoints you have shared here are much even surprising... excellent.
                                kwistenbiebel
                                Thanks Nomer,
                                I wish I had your artist skills and use these images as a starting point for a real painting...
                                I did do some paintings some years ago, but I can't control oilpaint that well as you can.
                                  Phil Rader AIA
                                  Can you explain a bit of the process for FryRender. Is it a standalone renderer? do you export the image from SU and import it to Fry. Is there a plugin for SU to work directly with Fry?
                                  Just curious how it compares to VRAY or Maxwell
                                  http://www.philrader.com
                                    kwistenbiebel
                                    Fry has a Sketchup plugin that contains a pulldown menu and an icon bar.
                                    When you have a material selected in SU's material list and click on the Fry paintbucket icon the Fry material editor pops up. Sun and sky setup has it's own panel, just as the general settings and camera panel.
                                    It takes some getting used to, but after some experimentation it works quite smoothly.
                                    You start the rendering by choosing the export>3dmodel>Fryrender in the file menu of SU.
                                    Once the export is done the FRY standalone GUI will pop up and the rendering starts.
                                    That GUI has a 3D viewport where you can change the view and you can also change mlaterials/environment/camera/render settings over there (actually the same things you can set up through the Plugin itself).
                                    The Fry standalone isn't as elaborate as the Maxwell studio as the developers wanted to make a 100% 'render from host' product.
                                    You can download a demo on the Fryrender.com website.
                                    It is fully operational (though the size image is max.800X600 and watermarked ).
                                    Cheers,
                                    Kwistenbiebel
                                      Jackson
                                      It's not so much emphasizing the female body as emphasizing a particular part of the female body. I'm not offended, but that last pic (and to a lesser extent the first one) is a bit tasteless IMO.
                                      Jackson
                                      • StinkieS Offline
                                        Stinkie
                                        With all due respect, I firmly disagree. If Christ's renders would have been pornographic, then you'd have a valid point. But are they pornographic? In my opinion: no. They merely show a naked body. Nothing wrong with that: the nude has been an artistic genre for centuries.
                                        Maybe it's because I studied art, but these images seem fairly 'common' to me. They're just your average tasteful, even bourgeois nudes. (Not meaning to insult you here, Christ.)
                                          kwistenbiebel
                                          Thank god for the open minded people. (cheers Stinkie )
                                          Personally I had it with the negative comments from the moderators.
                                          Too much nude, not enough Sketchup...
                                          Anything else?
                                          You're pushing me away here.
                                            boofredlay
                                            Hey, don't lump us all in one single minded category here 😄
                                            The only comment I made was a Booo to Eric's bad joke.
                                            I like the images. At first I thought to myself: "There is no way this is computer generated". So I had to look closer 😉
