    Key sequence in ruby
    10 Posts 3 Posters 2.1k Views 3 Watching
    • PixeroP
      Pixero
      How do I use a sequence of keys in ruby?
      I've tried with:
      if (key == 18 && key == 38) # Alt and Up Arrow
      and:
      if (ALT_MODIFIER_KEY && key == 38)
      and:
      if (key == ALT_MODIFIER_KEY && key == 38)
        RickW
        In a tool, when you define onKeyDown, it has a bunch of parameters:
        def onKeyDown(key, repeat, flags, view)
        The "flags" parameter will be a numerical value representing various events or combinations of events. The values are bit-coded and can be added for combined events:
        1 - Left MB
        2 - Right MB
        4 - SHIFT key
        8 - CTRL key
        16 - ???
        32 - ALT key
        So, CTRL+SHIFT+ALT would be a flag value of 44 (8+4+32)
        In your example, then, you want to check if flags==32 and key==38
        RickW
        www.smustard.com
        • PixeroP
          Pixero
          Thanks for your help, but it still won't work for me.
          Here is what I've done (a bit shorter than the real code):
           if (flags == 32 && key == 38) # Alt + Up
            dist = Geom;;Point3d.new [0, 0, 100];
           end #if
          # Now move it
          tr = Geom;;Transformation.new (dist);
          Sketchup.active_model.entities.transform_entities(tr, e);
          end # onKeyDown
          • T
            todd burch
            In my nudge script, I check for either the Shift Key or the Control key. I use the onKeyDown and onKeyUp methods to test for either key. When either key is pressed, I set a corresponding true toggle for that key. When it's raised, I set the toggle back to false.
            Finally, when I'm looking for the arrow keys, I test for true for either toggle and adjust the move distance accordingly. For instance, SHIFT+any arrow key is a 10X movement in distance.
            Todd
            • PixeroP
              Pixero
              Thanks I'll try that.
              • T
                todd burch
                Yeah, in the onKeyDown method, the keys are not OR'ed.
                You'll figure it out. Again, I recommend adding a "puts" statement as the first instruction in your methods to show the key code and you'll what see gets passed when.
                Todd
                • PixeroP
                  Pixero
                  YES! That worked!!!!
                  Thanks a lot.
                  As a side note. Do you have the keycodes for Mac?
                  On my laptop (Windows) the keycodes are:
                  up = 38
                  left = 37
                  right = 39
                  down = 40
                  alt = 18
                  shift = 16
                  ctrl = 17
                  • T
                    todd burch
                    Ignore any logic you see - this is from an old copy of a script. They keycodes are good though, for both Panther and Tiger, and I suspect they will be the same for Leopard too.
                    BTW, in OS X "Tiger" 10.4.10, the RUBY_PLATFORM constant is "fat-darwin8.8.0". If you check for "darwin" that should be good enough, thru Tiger anyways.
                    Todd
                    if !defined? KNUDGEOK then
                      if RUBY_PLATFORM == "i386-mswin32" then                 # Win XP
                        KALXMINUS = 37          # Arrow Left Key
                        KARXPLUS  = 39          # Arrow Right Key
                        KAUYPLUS  = 38          # Arrow Up Key
                        KADYMINUS = 40          # Arrow Down Key
                        KLTZDOWN  = 188         # (comma) Less Than Key
                        KGTZUP    = 190         # (period) Greater Than Key
                        KSHIFT    = 16          # Shift Key
                        KCONTROL  = 17          # Control Key
                        KNUDGEOK = true ;
                      elsif RUBY_PLATFORM == "powerpc-darwin" then            # Mac OSX Panther
                        KALXMINUS = 63234       # Arrow Left Key
                        KARXPLUS  = 63235       # Arrow Right Key
                        KAUYPLUS  = 63232       # Arrow Up Key
                        KADYMINUS = 63233       # Arrow Down Key
                        KLTZDOWN  = 44          # (comma) Less Than Key
                        KGTZUP    = 46          # (period) Greater Than Key
                        KSHIFT    = 131072      # Shift Key
                        KCONTROL  = 262144      # Control Key
                        KNUDGEOK = true ;
                      else
                        KPLATFORM = "?"
                      end ;
                    • PixeroP
                      Pixero
                      Again, thanks.
                      The only one missing is the Alt key.
                      • T
                        todd burch
                        Oops.
                        Command = 1048576
                        Alt = 524288
                        Control = 262144
                        The Command key, also known as the "apple" key, shown as a ⌘ in the Doc, is the Mac equivalent to the PC's CONTROL key. The control key on a Mac isn't used that often.
                        The ALT key is also named the Option key.
                        Todd
