    Finding a face's azimuth
    6 Posts 5 Posters 2.0k Views 5 Watching
      mocathe1st
      Hi all,
      Just wondering if anyone has any ideas on how to figure out a face's azimuth within sketchup. I've spent a while looking at this but haven't come up with anything too useful as yet. Any ideas would be greatly appreciated.
      My current value for azimuth is being calculated as such:
      def azimuth
      a = self.normal
      a.z = 0
      a.angle_between(Geom::Vector3d.new 1,0,0).radians
      but is not correct
      Best Regards
        todd burch
        No help here, but I would like to ask a faavor. Can you draw, in SU, an example that illustrates what an azimuth is? And, how an example one would be calculated? I went to wikipedia and I still don't get it.
        Thanks, Todd
          azuby
          @Todd
          Look here.
          azuby
          *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
          Bad English? PM me, correct me. :smile:**
            todd burch
            Well, that's easy enough to understand with a picture! Thanks azuby.
            So, all that's needed to determine the azimuth is
            1. you have to know the north angle
            2. you need the face normal.
            Right?
            I'm also guessing an azimuth value is worthless without some type of lat-long to go along with it. Is this correct?
            Todd
            • daikuD Offline
              daiku
              M:
              Do you need the angle in plan (projected down to the ground plane)? Also, be aware that the angle_between method will not return a negative value. It's always the absolute value of the difference, and it is that angle in 3D (not in plan). CB.
              Clark Bremer
              http://www.northernlightstimberframing.com
                RickW
                The problem is compounded by angles generally being measured counter-clockwise, while azimuth angles are measured clockwise.
                I think it would come down to determining the quadrant of the vector (by checking X and Y for +/- value), then adding the previous right-angle azimuth vector to the angle_between of it and the specified vector
                if vector.x>0
                  if vector.y>0
                    az = [0,1,0].angle_between(vector).radians
                  else
                    az = [1,0,0].angle_between(vector).radians+Math;;PI/2
                else
                  if vector.y<0
                    az = [0,-1,0].angle_between(vector).radians+Math;;PI
                  else
                    az = [-1,0,0].angle_between(vector).radians+(3*Math;;PI/2)
                The above example doesn't take into account cases where x or y equal zero, so you'll have to add that. It shouldn't be too difficult, though.
                RickW
                [www.smustard.com](http://www.smustard.com)
