Is there any script to get plane align to camera ?
I've try searching with google, find it, but to bad, google dismiss the Sketchup forum.
Thank for any help.
Regards.
Irfan R.[c1zone]
I'm not really sure there is a need for such a script.
If you right click a face, and choose Align View, does that do what you want?
Todd
What i'm trying to get is :
In my design has a few perspective view, it's related to rendering, because i'm using 2d texture for the plant, people and several other object. It's annoying when you render a perspective view i must get align all my 2d texture to face my camera one by one, and switch to another view and then......and then....Right now i'm using Sketchup 5, i've follow your instruction, but i think i miss something on my Sketchup (i don't see a sub menu 'Align with View').
Thanks so much
Irfan R.[c1zone]
Irfan,
It would seem that you need to investigate the "always face camera" property for components. This is most often used with 2D images used as objects as you describe. As the name suggests, they automatically turn (around the vertical axis)to face the camera, no matter what direction you view them from. It's discussed in the on-line Help.
-Gully
[Gully Foyle]
Maybe this will answer my question.
And Yes it is.Thanks so much Gully
[c1zone]
Gully,
thanks for the quick reply here... you contribute quite a lot around here... thanks... and Todd too of course...
Kris,
I find it's a good idea to keep an eye on things in case you try to pull a fast one.
-Gully
[Gully Foyle]
