    Texture exporting from SU
    4 Posts 3 Posters 1.4k Views 3 Watching
    • F
      firkins
      I would like to export all the texture maps from a SU file to a folder to ease the export of the file into KT (yes I do use SU2KT, but the file is so large it regularly misses a number of texture maps). I checked the Ruby library (Didier) and it seems that the texture writer script should do what I am seeking. However, I cannot get it to work (v6 pro).
      Is there a problem with this script, or is there another ruby that can do what I am asking?
      Michael
      %(#000080)["Those who would give up Essential Liberty
      to purchase a little Temporary Safety,
      deserve neither Liberty not Safety."]
      Ben Franklin
      • W
        Whaat
        Here's the code that I have been using in SkIndigo. It works pretty well for exporting all textures in your model (not just the ones in use). Of course, you will want to modify the output path.
        def export_textures
        tw=Sketchup.create_texture_writer
        model = Sketchup.active_model
        entities = model.active_entities
        helper_group=entities.add_group
        materials=model.materials
        for mat in materials
        	if (mat.respond_to?(;texture) and mat.texture !=nil)
        		helper_group.material=mat
        		tw.load(helper_group)
        entities.erase_entities helper_group
        status=tw.write_all $g_su2in_path_textures+"\\"+$g_su2in_textures_prefix+$g_su2in_model_name,false
        tw=nil
        return status
        Is this what you were looking for?
        Whaat
        • F
          firkins
          I'll try it, thanks.
          I also went back to the "old" place and did a search and came up with this suggestion:
          "Export your 3D model to an OBJ file. This will create a folder with all the texture files. Then you can delete the OBJ and MAT files if you don't need them."
          Not a ruby solution, but should work, too.
          Michael
          Ben Franklin
          • jujuJ
            juju
            Whaat, good to see you here at SketchUcation.
