user interface
hi,
i am developing a ruby module to draw a rack based on parameters. now the user interface is a excel file where user fills some values in cells, then a json is exported and the ruby reads the json and makes the drawing based on that.
i want to change this excel interface by an htmldialog inside sketchup. but it looks quite complex to do. i dont know much about html, css, javascript, etc...
i just to get something similar to the user interface i get already in excel, with some cells to get input and some cells to show some results (for example a simple calculation of the total length of the rack based in the user inputs).
what it is the best way to replicate that in ruby? i should use a visual editor the html + css, do there and the use that code for the ruby?
thanks
The
UI.inputboxinterface is the easiest way to create user inputs with Ruby. -
