    Terrain2Sketch. Easy terrain in to Sketchup
    4 Posts 1 Posters 110 Views 1 Watching
      k_arnese
      What do you think about the way Terrain2Sketch works.?
        k_arnese
        Terrain2Sketch – Development Update (August 2026)
        Hello everyone,
        I thought I'd share another progress update on Terrain2Sketch, my macOS application for importing GeoTIFF terrain directly into SketchUp.
        The project has now reached a point where I use it in real architectural projects, and during the last weeks several important improvements have been added.
        The original goal has never changed:
        Bring accurate terrain into SketchUp — fast, accurate and easy.
        Current workflow
        The workflow is now very straightforward.
        Select a folder containing GeoTIFF files.
        Terrain2Sketch automatically detects all adjacent tiles.
        Choose export resolution (0.5 / 1 / 2 / 5 / 10 meters).
        Optionally crop the terrain before export.
        Generate an optimized terrain mesh.
        Export directly to GLB.
        Import into SketchUp with a single menu command.
        The entire process usually takes only a few seconds for a normal building site.
        GeoTIFF support
        Terrain2Sketch has now been successfully tested with several different terrain datasets.
        Norway
        National Height Model (DTM)
        National Surface Model (DOM)
        EPSG:25833
        32-bit Float GeoTIFF
        United States
        USGS 1-meter DEM
        Successfully tested with:
        32-bit Float
        LZW Compression
        Predictor 3
        512 × 512 tiled GeoTIFF
        LZW decoding is now implemented directly inside Terrain2Sketch.
        Adaptive mesh generation
        Instead of exporting every raster point directly, Terrain2Sketch creates an adaptive terrain mesh.
        The result is:
        far fewer triangles
        much smaller GLB files
        faster SketchUp imports
        reduced memory usage
        while still preserving the terrain detail where it actually matters.
        Crop before export
        One feature that has become extremely useful is cropping before mesh generation.
        Instead of exporting an entire GeoTIFF tile, only the required area is processed.
        Benefits include:
        faster processing
        smaller files
        cleaner SketchUp models
        much less unnecessary geometry
        Coordinate information
        Each export now generates a small information file containing:
        GLB filename
        source folder
        EPSG code
        projected center coordinates
        latitude / longitude
        terrain extents
        number of GeoTIFF files used
        This makes it easy to relocate or document exported terrain models later.
        An interesting discovery
        While testing Norwegian terrain data I discovered something that may be useful for others working with GeoTIFF files.
        When ordering data from the Norwegian Mapping Authority, there is an enormous difference between downloading the complete source dataset and requesting a clipped export.
        For one recent test:
        Complete dataset
        ≈ 900 MB
        Clipped to the order polygon
        ≈ 640 KB
        Both datasets represented exactly the same project area.
        The difference was simply that one contained a huge amount of unnecessary surrounding raster data.
        Processing times became dramatically faster when using clipped datasets.
        It was one of those "why didn't I discover this earlier?" moments.
        SketchUp integration
        Terrain2Sketch exports directly to GLB.
        A small SketchUp extension imports the latest export automatically.
        No OBJ conversion.
        No intermediate software.
        No manual file browsing.
        Just one menu command inside SketchUp.
        Orbit video export
        The application can now also generate animated orbit videos directly from the terrain.
        Both formats are supported:
        Standard MP4
        Transparent video (MOV with alpha)
        This has turned out to be surprisingly useful when creating presentations and promotional material.
        Current status
        Implemented
        ✔ Multi-tile GeoTIFF support
        ✔ DTM
        ✔ DOM
        ✔ LZW compressed GeoTIFF
        ✔ Adaptive mesh optimization
        ✔ Multiple export resolutions
        ✔ Crop before export
        ✔ Terrain skirts
        ✔ GLB export
        ✔ Automatic SketchUp import
        ✔ Coordinate information export
        ✔ Standard orbit video
        ✔ Transparent orbit video
        What's next?
        There are still plenty of ideas for future development.
        Some possibilities currently being explored are:
        Orthophoto workflow
        Quad mesh export
        Additional SketchUp workflow improvements
        Windows version (long-term)
        Final thoughts
        Terrain2Sketch originally started as a small personal project because I was spending far too much time preparing terrain for SketchUp.
        It has gradually evolved into a complete workflow that I now use almost daily in my own architectural work.
        The amount of repetitive work it removes is honestly much larger than I expected when I started the project.
        I'm looking forward to sharing more progress in the coming weeks.
        As always, feedback, suggestions and testing ideas are very welcome.
        Thanks for reading!
        PS: I have also started creating short YouTube videos demonstrating the workflow. The first videos are already online, and I'll continue adding more as the project evolves.
        K 1 Reply Last reply Reply Quote 0
          k_arnese @k_arnese
            k_arnese
            Hi everyone,
            I’m looking for a few Mac users who would like to beta test Terrain2Sketch.
            Terrain2Sketch is a macOS application I’ve developed to quickly convert GeoTIFF terrain data (DEM/DTM/DOM)into terrain models and import them directly into SketchUp.
            The beta is working well in my own testing, but now I need some fresh eyes to find the things I haven’t found myself. 🙂
            Here’s a short video showing Terrain2Sketch in action:
            https://youtu.be/SurAszSHoy8?si=ofxkDkcXzkXzgbuT
            SketchUp Terrain From 25×25m to 100×100m in Seconds
            If you use SketchUp on a Mac and work with terrain, I’d really appreciate your feedback.
            If you’re interested, reply here or send me a private message and I’ll send you the beta download.
            Karl
