    Free of 2025
    348 Posts 6 Posters 137.5k Views 4 Watching
      Vfree izcom ( a very complex colored transparent engine)
      you can reake any 5 images from the screen and play again at the infinite! (not made here)
      PS no need prompt for the function "Mixed" !
        5 images Imagen 3
        Vizcom MIx 25 big zoom https://imgbox.com/g/oQcgbLBsoi
          Vizcom Mix
          pilouP 1 Reply Last reply
            pilou @pilou
            RODIN Ai
            Very complex colored transparent engine (Imagen 3) (Gemini)
            Rodin render 3D
            GLB inside 3D Builder (free) ---> export OBJ + mtl
            Base OBJ resultant : 18 502 sommets, 37 006 faces
            OBJ inside OBJ so Nurbs!!! (4 minutes on 12 years old latop! 🙂
            Import OBJ : Methode Create By File (native)
              Vue 2024 , PlantFactory, PlantCatalog at Bentley! 🙂
              https://fr.bentley.com/software/e-on-software-free-downloads/#faq
                10 Imagen 3 + 10 Minimax = 20 big zoom: https://imgbox.com/g/El3reVpK1u
                Winers
                Fonction Mix Vizcom
                50%
                90%
                20 %
                90% (minimax) 20 %Imagen
                20 %(minimax) 90 %Imagen
                25 big zoom https://imgbox.com/g/jzyrtxZwwt
                Some kitch results
                  Gemini 2.flash / Imagen 3
                  Funny to talk to the Ai!
                  It undertands all that i say! 🙂
                    TopMod + Vizcom
                      Gemini / Imagen 3
                        pilou @pilou
                        Here are 12 * 100 = 1,200 images of Alpaca!
                        A bit of everything, but they're all so “brilliant”!
                        Enjoy your visit
                        I had so much fun making them!
                        To see a larger version, of course, just click on the first image and then on the little arrow in the top right-hand corner!
                        12 galeries (page bottom) 😃
                        https://moiscript.weebly.com/alpaca.html
                          pilou @pilou
                            From POE
                            Imagen 3 Fast (2s)
                            Vizcom Mixed : The 30 Big Zoom The 30 Big Zoom : https://imgbox.com/g/UOQ84dcbNs
                            • L
                              Mind boggling stuff
                                Leonardo
                                Viz Mixed 30 big zoom https://imgbox.com/g/SoSje7dyK3
                                  Wombo
                                  Vizcom Mixed
                                  35 Big Zoom : https://imgbox.com/g/jV9DTdy9f4
                                    • L
                                      Hi Frenchie this image has caused a visceral effect on me for some reason I find the expression is the very definition of cold, gives me the shiversPIL.jpg
                                      L 1 Reply Last reply
                                        Maybe the little strabism!
                                        Take a heated blanket! 🙂
                                            Works fine for the free : 5 seconds 🙂
                                            • 17
                                            • 18
                                            • 4 / 18
