    Free de 2025
    258 Posts 4 Posters 53.4k Views 3 Watching
      Pas sûr que cette fonction spécifique soit accessible en free, mais il y a la même chose et pour le coup en vrai free chez Viscom https://www.vizcom.ai ! 😉
        Pfiou... y avait longtemps que j'avais été voir Leonardo...
        Il y a un nouveau mode "Flow" ! Un prompt amélioré, 4 choix de mode de rendus (20 chaque)
        Et hop en ce moment 300 en free/ jour ... une fois une image pondue, zou idem réglages et à l'infini...
        Sauvegardes possibles ou enregistrement dans sa biblio perso... ici même réglages donc variations
            J'avais entré : a very complex colored transparent engine
            Sympa il me donne un cours! :nerd:
            1 Conceptual Design:
            • Sketching: Start with rough sketches to outline the basic structure of the engine. Consider the components you want to include, such as pistons, cylinders, valves, and the cooling system.
            • Style: Decide on the style and complexity. For a futuristic look, you might incorporate sleek lines and unconventional shapes.
            2 Color Scheme:
            • Choosing Colors: Select a color palette that reflects the desired mood. For a futuristic engine, neon colors or metallic hues could work well.
            • Transparency Effects: Determine which parts will be transparent. This could include glass or clear plastic components, or even holographic elements.
            3 3D Modeling:
            -Software: Use 3D modeling software like Blender, Maya, or 3ds Max to create a digital model of the engine.
            -Detailing: Add intricate details to the model, such as textures, reflections, and shadows to enhance realism.
            4- Rendering:
            -Lighting: Set up lighting to highlight the transparent and colored parts of the engine.
            Materials: Apply materials with transparency and color properties to different parts of the engine.
            Final Touches:
            5 -Post-Processing: Use image editing software like Photoshop to add final touches, such as glows, lens flares, or other effects to enhance the visual appeal.
            • Animation: If desired, animate the engine to show it in operation, highlighting the moving parts and transparent sections.
            Would you like to see a visual illustration of this concept?
            Moi bien sûr : yes! 😃
                https://raphael.app/
                Bon du point de vue de la facilité ça le fait! 4 images par génération!
                Le sytème de "Download" ou Drag & Drop de l'image a merdoyé chez moi pour des raisons inconnues!
                Mais le Clic Droit/ copier l'image marche pour mon même vieux logiciel 25 ans!
                l'image fait 512 x 512 et en "enhance" 1024 x 1024
                Je ne crois pas que les images d'une session soient mise en bibliothèques!
                Il faut enregistrer en live!
                  Bizarre ça! Un autre encore plus zen (Prompt -> Generate) et meilleur me semble-t-il!
                  Et quasi du même nom! Tout free!
                  Vitesse de génération impressionnante! 1024 768 jpg
                  https://raphaelai.app/
                    Bouffre et on appuie sur le bouton à l'infini! https://raphaelai.app/
                    Style of Karol Bak, she's sitting on a pile of scrap robot parts, she's eating a butterfly, there's a weird machine on her head, out from the machine a swarm of robot butterflies are released
                    Prompt by Lana Rose
                    On change d'artiste, (Odd Nerdrum), quelques pronoms et hop une autre série infinie! 😅
                    Inutile de dire que ce petit jeu est sans fin!
                      Raphael AI - Free Unlimited AI Image Generator
                      Raphael AI is a free, unlimited AI image generator featuring top models including Nano Banana 2 / Pro, Qwen-Image, Seedream 5.0 for high-fidelity images.
                      Raphael AI (raphael.app)
                        On n'a même plus à écrire de prompt : on demande en 3 mots aux assitants AI d'écrire un prompt sur n'importe quels sujets et zou il n'y a plus qu'à choisir!
                        Et zou jusqu'à l'infini! https://raphaelai.app/ 1800 par heure le temps de cliquer sur le bouton!
                        Des dirigeables géants, flottant dans les airs grâce à l'hélium, offrant des panoramas époustouflants et des voyages paisibles. Imaginez des vaisseaux aériens capables de transporter des centaines de passagers, de servir de plateformes d'observation ou de servir de lieux de vie flottants
                        pilouP 1 Reply Last reply Reply Quote 0
                          pilou @pilou
                          5 voitures mixées dans Vizcom
                          Le reste... https://imgbox.com/rphTb580 et les flèches en haut à droite!
                            Après les vidéos Minimax fait des images fixes!
                            L 1 Reply Last reply Reply Quote 1
                              On voit de ces choses!
                              Raphaelai
                                https://gemini.google.com/app Gemini 2.0 Flash (Imagen 3)
                                  Raphaelai
                                    Imagen 3: 10 secondes, PNG, 512x 512
                                    Raphaelai: 1 seconde, direct jpg, 1024 x 1024
                                      Bloqué à 15 by Raphaelai! 😞
                                      https://imgbox.com/g/KtoN5f72G9 13 big zoom
                                        https://www.desmos.com/?lang=fr free https://www.youtube.com/@Desmos
                                          L i am @pilou
                                          @pilou I want one, I need one
                                            Gros test de la fontion Mix de Vizcom! 😃
                                            5 images maxi! j'ai repris les 5 images du Moteur Preraph de Leonardo! 😅
                                            Les 5 images avaient été générées avec le vieux free Wombo! 😃
                                            En fait cela revient à avoir un "moteur d'entraînement" en direct! 🤓
                                            Il faut 20 secondes pour une image! On peut donner un % !
                                            Les 5 lignes correspondent au cyclage vertical des 5 de base!
                                            50%
                                            10%
                                            100% - 10 %
                                            90%
                                            Free Krea
                                            • 12
                                            • 13
                                            • 1 / 13
