Desired Space 2.
I found myself forgetting to select GPU and decided to showcase the different styles here. The first is the CPU render and the second, much faster render, GPU. Normally the GPU setting would be brighter but not so here.
Also, the baqckgrouind appears split with differing light levels in the GPU version.
