    Free of 2024
    450 Posts 4 Posters 21.2k Views 5 Watching
      pilou @pilou
      red start image Fractal Lab free (online) !
      https://moiscript.weebly.com/fractal-lab.html
      10 big zoom https://imgbox.com/0q0xf2Fe
      pilouP 1 Reply Last reply Reply Quote 0
        pilou @pilou
        Inside Alpaca
          Free Chaoscope + Alpaca
          With the free Chaoscope
          Alpaca
          10 big zoom : https://imgbox.com/ox3UDlnR
            pilou @pilou
            So Speed! Free TopMod
            Alpaca
              pilou @pilou
              TopMod - Alpaca
              Objects can be duplicated!
                pilou @pilou
                Free TopMod
                Alpaca
                  pilou @pilou
                  From a Kyle's tutorial
                    pilou @pilou
                    TopMod <-- .OBJ
                    10 big zoom : https://imgbox.com/g/gjpdUMNfsq
                    Alpaca
                        pilou @pilou
                          pilou @pilou
                          pilouP 2 Replies Last reply Reply Quote 0
                            pilou @pilou
                            Alpaca
                              pilou @pilou
                              Alpaca Model Wind Mill by Bemfarmer
                                Model above by Bemfarmer
                                  In your favorite modeler
                                  export as OBJ + Ngons to TopMod
                                  Then Alpaca
                                    pilou @pilou
                                    TopMod: To have 2 objects, at first sight you have to import them together!
                                    However, you can duplicate (easily) and move (laboriously) an object(s) already on the screen!
                                    Join 2 identical or different facets!
                                    Hollowing tool and customizable edges... and image or OBJ export to Vizcom!
                                      Hollow and Wire tools A simple box and sphere, a small fillet...
                                      A simple box and a sphere, a little fillet...
                                      Export with Ngones mandatory since edible by TopMod!
                                      Face selection with SHIFT pressed! Just drag the mouse over faces...TopModel is great at selection acrobatics!
                                      The Wire tool lets you change ALL the edges at once! (There doesn't seem to be a “selective” selection for this function... To remove all the squiggles due to OBJ import, you need to delete them with the “Edge selection”, and the DEL key!
                                      Not to be confused with the “Edge Delete” Mode function, which deletes the drawing of Edges but not the faces! (Renders Vizcom)
                                        Free TopMod
                                          TopMod --> Alpaca
                                          Only for toys!
                                            pilou @pilou
                                            Alpaca
                                            • 22
                                            • 23
                                            • 5 / 23
