    Free of 2024
    451 Posts 4 Posters 182.9k Views 6 Watching
      pilou @pilou
      So sweet! Page bottom! : So strong TopMod!
      Topological Mesh Modeling
      (people.tamu.edu)
      pilouP 1 Reply Last reply
        pilou @pilou
        Alpaca (TopMod)
          pilou @pilou
          TopMod Vizcom
          Alpaca
            pilou @pilou
            red start image Fractal Lab free (online) !
            https://moiscript.weebly.com/fractal-lab.html
            10 big zoom https://imgbox.com/0q0xf2Fe
              pilou @pilou
              Inside Alpaca
                Free Chaoscope + Alpaca
                With the free Chaoscope
                Alpaca
                10 big zoom : https://imgbox.com/ox3UDlnR
                  pilou @pilou
                  So Speed! Free TopMod
                  Alpaca
                    pilou @pilou
                    TopMod - Alpaca
                    Objects can be duplicated!
                      pilou @pilou
                      Free TopMod
                      Alpaca
                        pilou @pilou
                        From a Kyle's tutorial
                          pilou @pilou
                          TopMod <-- .OBJ
                          10 big zoom : https://imgbox.com/g/gjpdUMNfsq
                          Alpaca
                              pilou @pilou
                                pilou @pilou
                                pilouP 2 Replies Last reply
                                  pilou @pilou
                                  Alpaca
                                    pilou @pilou
                                    Alpaca Model Wind Mill by Bemfarmer
                                      Model above by Bemfarmer
                                        In your favorite modeler
                                        export as OBJ + Ngons to TopMod
                                        Then Alpaca
                                          pilou @pilou
                                          TopMod: To have 2 objects, at first sight you have to import them together!
                                          However, you can duplicate (easily) and move (laboriously) an object(s) already on the screen!
                                          Join 2 identical or different facets!
                                          Hollowing tool and customizable edges... and image or OBJ export to Vizcom!
                                            Hollow and Wire tools A simple box and sphere, a small fillet...
                                            A simple box and a sphere, a little fillet...
                                            Export with Ngones mandatory since edible by TopMod!
                                            Face selection with SHIFT pressed! Just drag the mouse over faces...TopModel is great at selection acrobatics!
                                            The Wire tool lets you change ALL the edges at once! (There doesn't seem to be a “selective” selection for this function... To remove all the squiggles due to OBJ import, you need to delete them with the “Edge selection”, and the DEL key!
                                            Not to be confused with the “Edge Delete” Mode function, which deletes the drawing of Edges but not the faces! (Renders Vizcom)
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
