    Free of 2024
    450 Posts 4 Posters 30.6k Views 5 Watching
      pilou @pilou
      Alpaca (TopMod)
      pilouP 1 Reply Last reply Reply Quote 0
        pilou @pilou
        TopMod Vizcom
        Alpaca
          pilou @pilou
          red start image Fractal Lab free (online) !
          https://moiscript.weebly.com/fractal-lab.html
          10 big zoom https://imgbox.com/0q0xf2Fe
            pilou @pilou
            Inside Alpaca
              Free Chaoscope + Alpaca
              With the free Chaoscope
              Alpaca
              10 big zoom : https://imgbox.com/ox3UDlnR
                pilou @pilou
                So Speed! Free TopMod
                Alpaca
                  pilou @pilou
                  TopMod - Alpaca
                  Objects can be duplicated!
                    pilou @pilou
                    Free TopMod
                    Alpaca
                      pilou @pilou
                      From a Kyle's tutorial
                        pilou @pilou
                        TopMod <-- .OBJ
                        10 big zoom : https://imgbox.com/g/gjpdUMNfsq
                        Alpaca
                            pilou @pilou
                              pilou @pilou
                              pilouP 2 Replies Last reply Reply Quote 0
                                pilou @pilou
                                Alpaca
                                  pilou @pilou
                                  Alpaca Model Wind Mill by Bemfarmer
                                    Model above by Bemfarmer
                                      In your favorite modeler
                                      export as OBJ + Ngons to TopMod
                                      Then Alpaca
                                        pilou @pilou
                                        TopMod: To have 2 objects, at first sight you have to import them together!
                                        However, you can duplicate (easily) and move (laboriously) an object(s) already on the screen!
                                        Join 2 identical or different facets!
                                        Hollowing tool and customizable edges... and image or OBJ export to Vizcom!
                                          Hollow and Wire tools A simple box and sphere, a small fillet...
                                          A simple box and a sphere, a little fillet...
                                          Export with Ngones mandatory since edible by TopMod!
                                          Face selection with SHIFT pressed! Just drag the mouse over faces...TopModel is great at selection acrobatics!
                                          The Wire tool lets you change ALL the edges at once! (There doesn't seem to be a “selective” selection for this function... To remove all the squiggles due to OBJ import, you need to delete them with the “Edge selection”, and the DEL key!
                                          Not to be confused with the “Edge Delete” Mode function, which deletes the drawing of Edges but not the faces! (Renders Vizcom)
                                            Free TopMod
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
