    How to retrieve the structure of instance up to model?
    3 Posts 2 Posters 114 Views 2 Watching
      areal3d Newcomers
      hello,
      i just stuck at one point:
      wirh onmousemove i can get the instance/component - structure easily:
      pickhelper = view.pick_helper pickhelper.do_pick(x, y) pickhelper.count.times { |pick_path_index| pp=pickhelper.path_at(pick_path_index) }
      i can the iterate pp and get for example all transformations.
      now when i iterate thru entities of a certain instance and want to get the parent, i do not get the higher INSTANCE, but the DEFINITION LIST.
      how can i get the whole path as in the pickhelper from a selected instance?
      thanx a lot for helping .
      stan
      edit1 : found this interesting topic:
      https://forums.sketchup.com/t/what-is-the-way-to-get-an-instance-path-to-the-root-given-a-group-componentinstance/47274
      starting to check it out!
      edit 2:
      this works, but interesting:
      not the returned arry of elemnts holds the row, but the array[0]
      BUT IT WORKS FINE !!!!
      • Dan RathbunD Offline
        Dan Rathbun
        @areal3d said:
        hello,
        ... now when I iterate thru entities of a certain instance and want to get the parent, i do not get the higher INSTANCE, but the DEFINITION LIST.
        Instances do not have Entities collections. Only definitions and the top-level model have an Entities collection.
        I'm not here much anymore.
          Dan Rathbun
          @areal3d said:
          hello,
          You will either need to build an InstancePath as you drill down or get the Model.active_path and add the selected instance to it.
