    Can't Import Or Paste Components
    13 Posts 2 Posters 564 Views 2 Watching
    • Joe WoodJ Offline
      Joe Wood
      Folks, SUp 2022, I can't import, or Copy Paste components into a skp file I have open, all I see is the bounding box. Never had this happen before so what gives?
      Joe Wood
      woodsshop.com/
      • BoxB Offline
        Can you attach the model so we can check it to rule it out.
        • Joe WoodJ Offline
          Joe Wood
          Right on Box, OK I deleted lot of things but the people components I'm trying to insert are still in the components tab.
          https://www.dropbox.com/sh/3xpfww3dag1d2qa/AADoPgcfxq0WGaw_jcGgg33Ga?dl=0
          Joe Wood
          woodsshop.com/
          • BoxB Offline
            You have the relevant people tags turned off.
            • Joe WoodJ Offline
              Joe Wood
              I'm glad it was something easy, thanks for taking a look!
              Joe Wood
              woodsshop.com/
              • BoxB Offline
                No worries, you're welcome.
                • Joe WoodJ Offline
                  Joe Wood
                  I need to learn about Tags now! What were tags called before these SUp versions with the Tray?
                  Joe Wood
                  woodsshop.com/
                  • BoxB Offline
                    Tags were called layers, they behave the same, just a different name.
                    Only assign a tag to groups or components or dimensions etc, never to raw geometry.
                    • Joe WoodJ Offline
                      Joe Wood
                      Tanks again Box nice to have Layers back again!
                      Joe Wood
                      woodsshop.com/
                      • BoxB Offline
                        They never went anywhere, a rose by any other name...
                        • Joe WoodJ Offline
                          Joe Wood
                          How is it that there were already Tags in the manager, that were turned off? Or were those created during my Import attempts?
                          Joe Wood
                          woodsshop.com/
                          • BoxB Offline
                            If you import things from the warehouse you import all the foibles of the model, that can mean several unused or hidden tags/layers. So how you got all the tags is unknown to me. But it is the reason we often recommend that you open downloaded things in a separate file and clean them up before adding them to your model. Cleaning them up can include removing tags you don't want. Along with all sorts of possible junk and bad modelling.
                            • Joe WoodJ Offline
                              Joe Wood
                              No these were people.skp I've had since the early 2000s. Not a big deal now that I know about tags.
                              Joe Wood
                              woodsshop.com/
