    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 96.8k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      The version 1.5.9 of the PBR plugin fixes URL of required plugin (glTF Exporter).
      Download latest PBR plugin from the SketchUcation PluginStore.
        DH2002
        First, Is this Plugin works for Mac OS SketchUp 2018 Pro?
        I managed to Install it and I have SimLab USDZ exporter Installed that works fine.
        After I install this Plugin SketchUp crashes, cant even save or load any object?
        I can draw a new mesh and even open this plugin, Load maps etc but when the try export files Aplication Crashes?
        My SketchUp the doesent work properly until I deinstall this Plugin.
        / Daniel
        • samuel_tS Offline
          samuel_t
          / Daniel
          First, sorry for this late reply:
          This plugin is compatible with SketchUp 2017-2021 for Windows and should be compatible with SketchUp 2017-2021 for macOS.
          If this plugin crashes when you export model as glTF file, you can try to in order:
          1. Open "Window > Ruby Console".
          2. Copy-paste below code:
          PBR;;GlTF.export
          1. Press enter to execute above code.
          2. Send me a screenshot.
          • samuel_tS Offline
            samuel_t
            The PBR 2.x plugin for SketchUp will support real-time ray tracing. Work in progress:
            • pabloariasP Offline
              pabloarias
              Hi. From a month, more or less, I got a popup when SU starts that said something about a newer version 4.2.6 from this plugin and opens this SketchUcation page when message accepted. But I see no news here about newer releases of this plugin. Does anybody here tell me what's wrong?
              Pablo Arias
              SketchUp trainer
              V-Ray licensed trainer
              • chonC Offline
                chon
                Hello,
                I think this message is about the last version of SketchUcation ExtensionStore ๐Ÿ˜‰
                • samuel_tS Offline
                  samuel_t
                  @chon said:
                  Hello,
                  Yes, it makes sense! ๐Ÿ˜„
                  • samuel_tS Offline
                    samuel_t
                    Hi Pablo.
                    4.2.6 ? ๐Ÿ˜• I'm working on the 2.x version of the PBR plugin but the latest public version available at SketchUcation is 1.5.9.
                    • Didier BurD Offline
                      Didier Bur
                      Hi Samuel,
                      First thanks for this great plugin (just like all of your other goodies).
                      Some questions about the materials:
                      -what is the difference between the heightfield map and the normal map features ?
                      • how to get an occlusion map based on a jpg texture ?
                      I'm starting some tests and amazed with the results ๐Ÿ˜‰
                      Thanks for your time.
                      DB
                      • samuel_tS Offline
                        samuel_t
                        @didier bur said:
                        Hi Samuel,
                        Hi Didier,
                        That's very kind! ๐Ÿ˜„
                        The height map in the PBR 1.x plugin is a parallax occlusion map. The height map is a grayscale image which simulates a "deep relief". You can use a displacement map from Poly Haven (for example) as a height map. Whereas the normal map encodes the "bas-relief" in the RGB channels of an image...
                        Handmade or automatic? Some softwares can autogenerate an [ambient] occlusion map from a diffuse texture...
                        Stay tuned ๐Ÿ˜‰ The PBR 2.x plugin should reach photorealism.
                        You're welcome!
                          Didier Bur
                          Hi Samuel,
                          Thanks for your answers.
                          I'm curious to know why each time I launch Sketchup I get the message:
                          It loads the Web page where I can dowload version 1.5.9. ๐Ÿ˜ฎ
                          Where can I find version 4.2.6 ?
                          Best regards,
                          DB
                          • chonC Offline
                            chon
                            Hi Didier,
                            I think you've got the same problem as on this post :
                            @chon said:
                            Hello,
                              Didier Bur
                              Merci !
                              ๐Ÿ‘
                              DB
                              • samuel_tS Offline
                                samuel_t
                                The PBR 2.x plugin for SketchUp could render the atmosphere with volumetric clouds in real-time.
                                  A partir de quelle version c'est compatible? โ˜€
                                  • samuel_tS Offline
                                    samuel_t
                                    Hello Pilou ๐Ÿ˜„
                                    It should be compatible with SketchUp 2017+.
                                      ๐Ÿ‘
                                      • 6 / 6
