    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Artisan mesh to solid
    Scheduled Pinned Locked Moved Organic Modelling
    3 Posts 2 Posters 5.2k Views 2 Watching
      kasinside
      Making a surface drape with Artisan, and need it to be a solid to use SU Solid tools afterwards on other geometry.
      The Artisan geometry is the problem no matter what I do. Solid inspector points out border of geometry as the problem - but can not see any problems along the border of geometry. What am I missing ?
      • BoxB Offline
        If you are seeing border geometry it usually means there is a hole or your shape has no thickness.
        A solid has to be a manifold shell of faces, a watertight container, otherwise it is just a mesh.
        There are other basics about solids but without seeing what you have it is all guesses.
          kasinside
          That must be it - no thickness to my mesh - thanks ๐Ÿ˜„
