    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Steel handrail
    8 Posts 5 Posters 2.3k Views 5 Watching
    • alvisA Offline
      alvis
      Steel railing system. Practice for me. Postpro - TwilightRender
      • Bryan KB Offline
        Wow! Well done. Great model and render. Love the simplicity. πŸ‘
        • BoxB Offline
          You know you've done a great job when someone pulls you up on a technicality.
          You never have glass to metal without a flexible spacer. There would be a thin spacer between the glass and the fitting, usually black or clear white, and it would be in the hole as well which would cause that to look ever so slightly different, and the hole being a drilled hole would have a ground surface.
          I really couldn't resist, had to find a fault somewhere. πŸ’š
          • alvisA Offline
            alvis
            Yes. You're right. I needed to pay attention to that. After all, I knew it. The part that points to the glass is black and very thin, but the rod is steel. He really had to be black.
            Well here’s a new technology, a test product πŸ˜†
            • pbacotP Offline
              Awesome!
              • jo-keJ Offline
                jo-ke
                wow! very good!
                what are the material settings for the steel!
                http://www.zz7.de
                • alvisA Offline
                  alvis
                  @jo-ke said:
                  wow! very good!
                  StainlessSteel template with Sketchup texture
                  • jo-keJ Offline
                    jo-ke
                    thank you.
                    http://www.zz7.de
