    [REQ] remove backface materials (selected)
    10 Posts 5 Posters 7.4k Views 5 Watching
    • pbacotP Offline
      Does anyone know of a plugin that can remove backface materials from a selection. I use TT's Material tools which are excellent. But the actions seem to work on the whole model instead of selections, and removing materials from ALL backfaces is a problem when I just need to work on a specific selection.
        If you inverse Selection / Hide then Remove that works not ? (not tested)
          rv1974
          put selection in separate file, run TT tools and paste it back- what's the problem?
          • BoxB Offline
            If you are within a group you can use the Specific Material option to remove the backface material without effecting other backfaces.
            Edit: actually you don't need to be in groups, Remove Specific works on selection not entire model.
            • pbacotP Offline
              Thanks going into every group is what I was hoping to avoid. If there's nothing out there, I can deal with it these different methods.
              • BoxB Offline
                You don't have to go into each group, if the material is only on the back faces you can select groups components and raw geometry and it will remove the chosen material from anywhere in the selection while leaving the rest of the model alone. If the material is both back and front then this wouldn't work.
                • pbacotP Offline
                  Now i see what you mean--that's a different approach to the same solution. Thanks!
                    dezmo
                    @pbacot said:
                    Does anyone know of a plugin that can remove backface materials from a selection... I just need to work on a specific selection.
                    Dezmo_remove_back_materials.rbz
                    Here are a quick one...This will remove Back Face Material from selection recursively. You can undo it.
                    Start by toolbar icon or context menu after selection.
                    The result will be printed out to Ruby Console e.g.:
                    "Back Face Material removed from 11 faces."
                    or
                    "Back Face Material removed from 0 face."
                    Quickly tested only on Windows. No responsibility... but should be okay on MAC too.
                    (Sorry about the ugly icon 😳 )
                    #main.rb
                    module Dezmo
                      module Remove_Back_Mat
                        @@loaded = false unless defined?(@@loaded)
                        extend self
                        def remove_back_materials
                          model=Sketchup.active_model
                          model.start_operation('Remove Back Face Materials', true)
                          @count = 0
                          remove_back_materials_recursively
                          plural = @count > 1 ? "s" ; ""
                          p "Back Face Material removed from #{@count} face#{plural}."
                          model.commit_operation
                        def remove_back_materials_recursively(ents = Sketchup.active_model.selection)
                          ents.each { |e|
                            case e
                            when Sketchup;;Face
                              if e.respond_to?( ;back_material ) && e.back_material
                                e.back_material = nil
                                @count += 1
                            when Sketchup;;ComponentInstance, Sketchup;;Group
                              remove_back_materials_recursively(e.definition.entities)
                        unless @@loaded
                          cmd1 = UI;;Command.new("Remove Back Face Materials") {remove_back_materials}
                          cmd1.small_icon = File.join(File.dirname(__FILE__), "/rbm.png")
                          cmd1.large_icon = File.join(File.dirname(__FILE__), "/rbm.png")
                          cmd1.tooltip = "Remove Back Face Materials"
                          cmd1.status_bar_text = "Remove Back Face Materials (Selection required)"
                          cmd1.set_validation_proc {
                            if Sketchup.active_model.selection.empty?
                              MF_GRAYED | MF_DISABLED
                            else
                              MF_ENABLED
                          UI.add_context_menu_handler do |context_menu|
                            context_menu.add_item(cmd1) unless Sketchup.active_model.selection.empty?
                          toolbar1 = UI;;Toolbar.new("Remove Back Face Materials")
                          toolbar1.add_item(cmd1)
                          toolbar1.restore
                          @@loaded = true
                    Man can do everything. Only a matter of time and money.
                    • BoxB Offline
                      Nice one Dezmo.
                      I really must learn to code one day.
                      • pbacotP Offline
                        Wow! Thanks so much for writing that! It works great! πŸ‘ πŸ‘ πŸ‘
