    Open/Close Trays with a button?
    15 Posts 3 Posters 4.2k Views 3 Watching
    • N
      numerobis
      @rv1974
      I have at least 3 trays for which i want to toggle visibility. I already use a ton of shortcuts, 5 of them are assigned to mouse buttons. I currently have defined separate trays for "Materials", "Shadows", "Entity Info" and "Smoothing" and have mapped the toggle command to some "F" keys. But yes, if there is no other solution, i will have to work with 3 or 4 shortcuts more.
      • BoxB
        You do know that if you just click the titlebar of one of the dialogs in your tray it will 'roll up'.
        So even just using the default tray it can be, mouse over, click pin, click title, do what you want. click title, click pin, and all is gone again.
        • N
          numerobis
          @Dave R
          I'm still using v2015 because the last SU version that is supported by Maxwell Render v3 is v2017, which didn't gave me anything that was worth the upgrade, because i don't like the tray system.
          I had renewed the maintenance for 2019 to keep it alive and this year to get 2021 as the last SU version, but didn't activate anything newer than 2015. But i think i'll have to switch to 2021 in the the near future because more and more plugins need newer versions, so i'm now trying to find a setup that works for me.
          • BoxB
            So you are questioning/complaining about a system you don't even use, therefore don't understand.
            • N
              numerobis
              sure, but not the tray itself.
              • BoxB
                A single click on the pin opens or closes the tray.
                • N
                  numerobis
                  I thought i've understood the system quite well, but maybe i've overlooked something and you can tell me how i can minimize/maximize floating trays with a single click. I'd like to have 3 of them side by side at the top of the screen. As far as i know, to be able to minimize a tray it needs to be docked (which would be to the right or left side) and to maximize a tray and keep it open i need two clicks (or mouse over + click) at two different points.
                  • BoxB
                    How about you try it for yourself and see what works for you.
                    You can have three separate windows floating, or more, on different monitors.
                    You can have multiple trays as tabs on the same docked or floating 'Tray'.
                    There are many ways to organise your trays, no two people will use them the same way.
                    I personally have a fairly standard tray docked unpinned to the right of my workspace which I pin when needed. But I also have a short tray bottom left that shows entity info at all times and has outliner as a tab. Outliner is now very functional and doesn't need to be closed, but I still tend to keep it closed, showing my age.
                    • N
                      numerobis
                      I think that's what i'm doing and have done since the tray system has been released. This is how my setup looks so far...
                      https://abload.de/img/traysxcjy8.png
                      On this 4k screen covered space isn't that much of a problem. But i have another workplace with only 1440p.
                      And one problem that i have with docking and pinning of trays is that this always changes the aspect ratio/field of view. So this isn't really a good option for me.
                      • BoxB
                        You have access to a very customisable system, I cannot add anything.
                        • BoxB
                          My last comment on this.
                          You can even stack trays together, floating or pinned.
                            rv1974
                            @nuberosis
                            Currently your layout looks messy. Just group all into ONE default tray and toggle its visibility with ONE aux mouse button. BTW most of the time all trays should be normally closed which is beneficial for program performance
