    Ruby code editor
    3 Posts 2 Posters 1.7k Views 2 Watching
    • O Offline
      odowhacker
      hallo all,
      i am trying to get used to ruby again - working with the ruby code editor 4.3 and sketchup pro 2016.
      working with one of the script examples 'using formulas for patterned panels' i'm running into a problem when i try to modify this script slightly.
      the example is about drawing circles in a plane. i'm trying to add faces to these circles and extrude them to cylinders. i'm getting errors that seem impossible to me - so i need your help.
      after much browsing QA articles with helpful responses for instance by TIG i noticed that possibly the error might have to do with the editor.
      script:
      Script sample from Alexander C. Schreyer's book
      "Architectural Design with SketchUp"
      Creates a square panel with a sinusoidal hole pattern
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      width = 36 # Width of panel
      n = 10 # Number of circles in each direction
      s = width / (n+1).to_f # Spacing of circles
      w = 50
      Add the square base for the panel
      face = ent.add_face [0,0,0] , [width,0,0] , [width,width,0] , [0,width,0]
      Iterate in the panel plane
      (0..n-1).each { |i|
      (0..n-1).each { |j|
      # Create a group for each circle
      group = ent.add_group()
      ents = group.entities
      # Add the circle
      centerpoint = [s+is,s+js,0]
      vector = [0,0,1]
      radius = Math::sin( i / (n-1).to_f * Math::PI ) * s / 5.0 + Math::sin( j / (n-1).to_f * Math::PI ) * s / 5.0
      edges = ents.add_circle centerpoint , vector , radius , 24
      #various trial and error to get a face inside
      #edges[0].find_faces
      #cface = edges[0].faces[0]
      cface = group.entities.add_face edges
      cface.back_material = [ (255 / (n-1)*i).round , (255 / (n-1)*j).round ,(255 / (n-1)*j).round ]
      #face.pushpull -w
      group.explode
      the add_face command is followed by error: not enough edges
      if i omit the command i'll get error: undefined method 'back_materia=' for nil so a face isn't created no matter which approach i use.
      the ruby console tellsme:
      "undefined method back_material=' for nil:NilClass (Line 37)" Error: #<TypeError: no implicit conversion of NoMethodError into String> C:/Users/errfitt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/as_rubyeditor/as_rubyeditor.rb:346:in +'
      C:/Users/errfitt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/as_rubyeditor/as_rubyeditor.rb:346:in rescue in block in initialize' C:/Users/errfitt/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/as_rubyeditor/as_rubyeditor.rb:368:in block in initialize'
      SketchUp:1:in `call'
      can someone tell me what's wrong and what i can do to solve this?
      thanks a bunch
        McGordon
        The first time your nested i, j loop runs, i and j are both zero, so your radius will be zero as sin(0) = 0.
        The add_circle method is called with:
        add_circle([3.272727272727273, 3.272727272727273, 0], [0, 0, 1], 0.0, 24)
        which has a radius of 0.0 so it will sort of fail and return 2 edges instead of 24. Then you won't be able to find faces when there's only 2 edges and you'll get the errors you saw.
        I haven't used that code editor or read that book. The error is nothing to do with your editor. As I don't have access to the book I don't know which parts you've changed.
        I'm not entirely sure what it's supposed to look like, but here's what I've got.
        https://i.imgur.com/NLjsWml.png
        I put it all in a group so it doesn't stick to existing geometry. I just erase the failed groups where add_circle fails to form a circle with 24 segments. You could check for radius being 0.0 but there's also some cases where it's extremely small e.g. i=9, j=9 where the radius is 1.6e-16. I left in some of puts statements I had for debugging to let you see what's going on.
        Odowhacker.rb
        • O Offline
          odowhacker
          thank you very much. πŸ‘
