โ„น๏ธ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
More older stuff
8 Posts 3 Posters 5.9k Views
    CJRyan
    In that, I milled most everything but the ply-wood used, I guess this is "woodworking".
    I modeled and built this from a concept sketch. I've revised the original model to reflect the "as-built" state.
    The walls, ceiling, and floor were 1/4 inch steel welded in place, so every attachment point was drilled and tapped.
    The two back panels on the right and left are mounted on cantilevered slides to access and hide my client's full-automatic guns.
    Because the man had both double-barrel and single barrel rifles, I designed some upper receivers that are mounted using magnets, so the guns could be positioned as he wished.
      Really nice, well concieved and executed design CJ and thanks for sharing been a bit quite in that area. I find the render a bit half baked and not at all covincing ๐Ÿ˜‰
        robertWan
        @l i am said:
        render
        Render?
        This is probably the actual appearance of the furniture.
        Robert
          CJRyan
          I'm fairly sure L i am was kidding. I only wish I could render that well.
            robertWan
            This confused me. ๐Ÿ˜„
            Robert
            plug
              @robertwan said:
              @l i am said:
              render
              Render?
              Robert
              Hi Robert, sorry mate that was a (probably bad) joke. I was aware it was a Photo, indicated by the "wink" at the end ๐Ÿ˜‰
                CJRyan
                L i am, in that I know you, I found it funny.
                For hahas, I found another "render" of the hidden panel.
                  [attachment=0:2g99z550]<!-- ia0 -->Gunroom Panel.jpg<!-- ia0 -->[/attachment:2g99z550]
                  Hi CJ, not sure Stinkie would appreciate you taking credit for his work ๐Ÿ˜‰
