    Seeking upholstery suggestions
    10 Posts 5 Posters 6.0k Views 5 Watching
      davidheim1
      moran loveseat.pngI've been working on a model of this loveseat off and on for a couple of weeks. I'd like to show the tufting on the back, but I'm not sure how to accomplish that. I've tried using the Sandbox tools, but with little success. I suppose SubD would work, but I have no experience with that plugin. Any suggestions?
      Best,
      dh
        Look at Alvis furnitures thread! πŸ˜‰
          davidheim1
          Some interesting models, but not a lot of hard information in the thread. It looks as if he's using Vertex Tools or SubD, but I can't tell.
          Thanks for the tip, though. Much appreciated.
          Best
          dh
          • BoxB
            David, posting questions like this in the Woodworking section sort of limits who sees it. You have to choose to see this category.
            But here is a quick gif showing you the very basics of making tufting.
              davidheim1
              Thanks, Box, for taking the time to do the GIF. It looks as if SubD is what I need. I was hoping I could avoid buying a plugin to finish this model. Oh, well.
              • BoxB
                There are several ways I can think of to do it, I responded to your comment that there was little info on how it was done with Vertex tools and SUbD.
                You could achieve good results with Curviloft or even follow me. You just need to work with multiple sections in a suitable configuration.
                • ntxdaveN
                  ntxdave
                  Would be interesting to see how you would achieve this with follow me and/or Curviloft
                  Press F1...thank me later
                    davidheim1
                    tufting test.pngCurviloft will work but it's time-consuming. The image is a test I did just now. It entails creating one tufted square and copying it repeatedly. That's OK for the flat part of the back, but it will probably get tricky when I try to create tufts on the curved part of the piece.
                      jtri
                      Nice model David. Thanks for sharing your process and problems. Let us know how you finally decided to finish the model.
                        davidheim1
                        SubD and Vertex Tools were on sale today from SketchUcation. I bought both and will probably use them for the tufting. If I can learn how to use these plugins, that is. Stay tuned.
