    Undoing all transformations
    5 Posts 3 Posters 4.1k Views 3 Watching
    • F Offline
      Frankn
      I'm pretty sure I've seen this before but I can't find the answer... so sorry in advanced if this is a repeat question.
      I'd like to remove all transformation for a given instance... so basically reverse what ever moves and rotations were done.
      I can get the transformation array,
      e.transformation.to_a
      and i tried setting everything back to 0 bu that didn't work...
      • sdmitchS Offline
        sdmitch
        Maybe this?
        mod = Sketchup.active_model
        ent = mod.entities
        sel = mod.selection
        cmp=sel.first
        t=cmp.transformation.to_a
        t[0]=1;t[1]=0;t[2]=0;#t[3]=nil
        t[4]=0;t[5]=1;t[6]=0;#t[7]=nil
        t[8]=0;t[9]=0;t[10]=1;#t[11]=nil
        t[12]=0;t[13]=0;t[14]=0;#t[15]=nil
        cmp.transformation=cmp.transformation.set! t
        http://sdmitch.blogspot.com/
        • F Offline
          Frankn
          sdmitch, just had a chance to try it out and it does work...
          • fredo6F Offline
            Also, to reset all transformations and puts the instance g at the origin, just use
            g.transformation = Geom::Transformation.new
            If you have a state before some transformations are made to the instance, you can save the state with ( clone is important)
            tr0 = g.transformation.clone
            Then, later, you can resume this state with
            g.transformation = tr0
            Note that the transformation of an instance corresponding to g.transformation is always in the context of its parent.
            • F Offline
              Frankn
              Thanks for all that info fredo... It'll certainly come in handy
