    Potential Project
    21 Posts 6 Posters 11.3k Views 6 Watching
    • Didier BurD Offline
      Didier Bur
      Here is the first attempt to code what you want (I hope).
      Usage:
      Unzip the archive and place NumberingText.rbs in your Plugins folder
      Restart SketchUp
      Select 'Numbering Text' in the 'Extensions' menu
      Fill the dialog
      Prefix will precede the number (you can include spaces and \n sequence)
      Suffix will follow the number (you can include spaces and \n sequence)
      N.B.: a \n sequence in a text will reject the rest of the text on a new line.
      Altitude will be the height of all the texts above ground
      Click to insert label(s) , Right-clic to change settings, Escape to cancel, Return to end the tool.
      Examples:
      NumeringText.zip
      DB
      • pbacotP Offline
        That looks excellent!
        • O Offline
          Odewallrus
          Didier Bur,
          Thank you. That is awesome! Just what I was looking for. I would like to see only a single enhancement, if it is possible and you would be so kind...
          Are you able to make the text string centered with the mouse click versus left justified at the insert point?
            Didier Bur
            @odewallrus
            I'm afraid I can't 😳 . Unfortunately text entities in SketchUp are very basic (as opposed to text in Layout), and they do not have justification properties (because they are automatically left or right justified, depending on the arrow and pin features).
            I've tried to move the text a little to the left, but this translation depends on the text font and text height, it never gives a good result. A workaround would be to click slighty to the left of the location you want, knowing how long the text is, how big the font is, etc.
            Best regards,
            EDIT: I found that using 3DText will do the trick. I'll investigate this πŸ˜‰
            DB
            • O Offline
              Odewallrus
              Didier Bur,
              If it is possible with the 3d text or not, Thank you very much. This will be an incredible help that I can use immediately. I am currently finishing up an 1200du project which prompted my initial 'Potential Project' suggestion. I was not expecting anything as polished and flexible as your script, and surely nothing so quickly. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
              I sooooo owe you a beer or 3.
                Didier Bur
                @odewallrus:
                Here is the second attempt, with it you can insert either 2D texts (like before) and 3D texts (these will be centered on your clicks.
                Install:
                Unzip the archive and place Numbering2D3DText.rbs in your Plugins folder (remove any old version)
                Restart SketchUp, select your option (2D or 3D) in the Draw menu
                2D Text Usage:
                Fill the dialog:
                • Prefix will precede the number (you can include spaces,\n or \t sequences)
                • Suffix will follow the number (you can include spaces,\n or \t sequences)
                • Text altitude will be the height (in your current units) of all the texts, above ground (you can use negative values)
                • Click to insert label(s) , Right-clic to change settings, Escape to cancel, Return to end the tool.
                3D Text Usage:
                Fill the dialog:
                • Prefix will precede the number (you CANNOT include spaces,\n or \t sequences)
                • Suffix will follow the number (you CANNOT include spaces,\n or \t sequences)
                • Text font: enter a font name like Arial, Verdana, Tahoma, Times New Roman, etc.
                • Font Height: the height of the characters, in your current units
                • Extrude: the width (or depth) of the characters
                N.B.: 3D texts will be centered around the points you click, in top view.
                Enjoy ! 😎
                Numbering2D3DText.zip
                DB
                • O Offline
                  Odewallrus
                  Version 2 works great. Thank you, again. πŸ‘
                    Didier Bur
                    Here is the very last final version (I swear) πŸ˜†
                    More options for the 3d texts settings:
                    Some examples:
                    DB
                    • O Offline
                      Odewallrus
                      Those are very nice enhancements. I will try it today on a project. TY.
                      • O Offline
                        Odewallrus
                        Very nice enhancements!
                        • jujuJ Offline
                          juju
                          Neat! Now copy and paste this to Layout API please. 😜
                          (Yes, I am very well aware it doesn't work that way, just commenting on the lack of LO enhancements and wishing we had something like this there.)
                          • O Offline
                            Odewallrus
                            yup... that would be cool.
                            • Dan RathbunD Offline
                              Dan Rathbun
                              I see at least 1 missing feature. The text label layer.
                              (Imagine having to select all those text objects to change their layer?)
                              Workaround is to create and change to a "Text" layer (named whatever you please) before creating the text.
                              I'm not here much anymore.
                                Didier Bur
                                @Dan:
                                Layer feature done πŸ˜‰ See here: https://sketchucation.com/forums/viewtopic.php?f=323&t=70361
                                DB
