    How to SP 3.4 and KerkyThea
    22 Posts 6 Posters 25.1k Views 6 Watching
      Anton_S
      For step 5, the export statistics will be shown after you finish with the rest of steps.
      For step 7, you get two setting dialogs. One dialog is for export options, then once you click OK, the other dialog with animation export options will show up. I.E there are two options dialogs that will show up in the process. I will update instructions in first post, so they sound clear.
      When using MakeAVI, set compressor option to Full Frames (Uncompressed) for good quality. It will show up after you click the Begin! button and set export path.
        aviv
        to be more specific - after the first dialog <export option> <ok> i get an open file <locate kerkythea program, please>
        no second dialog.
          Anton_S
          Oh, that's because you also have to install Kerkythea. Once you do so, upon the first try you have to locate Kerkythea.exe, which is most likely in C:\Program Files\Kerkythea Rendering System\Kerkythea.exe
            aviv
            of course i dowloded the kerkythea and it is on program files (x86) (and working
            i succeed exporting a modle) .but where should i locate it?
            thnks for your help
              Anton_S
              thnks for your help
              You locate it there where you saved it. After you adjust settings in two dialogs (Step 7), you get another window, asking where to save the script and animation files...
                aviv
                nothing new it the same. maybee i missing a file i see "kerkythea rendering system" but no "kerkythea exe"?????
                  Anton_S
                  I don't know what you doing wrong, nor I understand what's the problem.
                  Lets go back to initial steps:
                  • Do you have SketchyPhysics 3.5.x installed?
                  • Do you have KerkyThea Application installed?
                  • Do you have SU2KT 3.17+ Plugin installed?
                    aviv
                    once again i want to thank you for your help.
                    i uninstall kerkythea and install it again and now it is locate and working 😍
                    i made a simple polygon a cube moving across the frame rendring 4 frame just to see if i am doing ok
                    it is rendring for more then an hour. how do i now when it finished?
                    what is the next step ?
                    iam planing upgrade to pro 2015 is physics get along with it?
                    THANKS
                    aviv
                      Anton_S
                      Speaking of rendering, Kerkythea application has its own progress clock:
                      This clock will disapera when the rendering is complete. It's not a rocket science...
                      And before rendering, I suggest using TT CleanUp plugin to remove all unused components and geometry. It will improve the speed of rendering.
                      See the list in first post for next step.
                      SketchyPhysics will not work in SU2015 64bit, but it will work in SU2015 32bit.
                      • V Offline
                        valerostudio
                        Will we see support for VRay anytime in the future?
                        • 2 / 2
