    Combining components into 1 component
    6 Posts 2 Posters 3.9k Views 2 Watching
    • K
      ktkoh
      I am bringing 3 parts (components) which are placed such that if all 3 are exploded and then all selected and made a single component. I have not been able to accomplish this with the API. Any suggestions
      Keith
      • K
        ktkoh
        I worked on this some more and found a Solution.
        Created a new layer
        added each comp to that layer
        exploded each comp
        cleared selection
        added all entities on the layer to the selection
        added selection to new group
        cleared selection
        added group to selection
        I could now make the group a solid I did not need a component at this point.
        • sdmitchS
          sdmitch
          Keith
          1. Create a group
          2. Add instances of each component to the group and explode
          3. Convert group to component.
          mod = Sketchup.active_model
          ent = mod.active_entities
          sel = mod.selection
          SKETCHUP_CONSOLE.clear
          grp = ent.add_group
          cmp = grp.entities.add_instance(mod.definitions["component#1"],IDENTITY);cmp.explode
          cmp = grp.entities.add_instance(mod.definitions["component#2"],IDENTITY);cmp.explode
          cmp = grp.entities.add_instance(mod.definitions["component#3"],IDENTITY);cmp.explode
          cmp = grp.to_component;cmp.definition.name="Cmps1-3"
          http://sdmitch.blogspot.com/
          • K
            ktkoh
            I will try Mitch's code. Question there are 2 constantans I am not familiar with in your code. SKETCHUP_CONSOLE.clear and IDENTITY.
            The problem with my version is that the entities that make up the final are on the Components layer not layer0. In the code I thought I was moving them back to layer0 but it didn't work and it didn't flag an error.
            @sss.clear
            		ents = []
            		@entities.each { |e| ents << e if (e.layer.name == @assy_Name) && ( ! e.is_a?(Sketchup;;Group) && ! e.is_a?(Sketchup;;ComponentInstance) )}
            		ents.each { |e| e.layer.name = "Layer0" }
            		@ss.add(ents)
            		copedRail = @entities.add_group(@ss)
            		@ss.clear; @ss.add copedRail
            		copedRail.layer = @assy_Name
            Keith
            • sdmitchS
              sdmitch
              SKETCHUP_CONSOLE.clear simply clears the Ruby Console so any errors that occur will be more obvious.
              IDENTITY is the same as Geom::Transformation.new().
              • K
                ktkoh
                Thanks Mitch your code worked very well once I figured out the transformation I needed. The code also left the component entities on Layer0 which was a problem for my code.
                The forum is an amazing source of info thanks to the many people who are willing to share their knowledge.
                Keith
