    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Half-round rope molding
    7 Posts 4 Posters 2.4k Views 4 Watching
      pipingguy
      before i physically mutilate the pre-finished poplar subject item that's supposed to adorn a cabinet-top crowne molding with an outside corner, i tried doing it with skp....but with no luck. maybe if the two workpieces had opposite hands, but they don't.
      rope molding quandry.skp
        The trick is to join both pieces of molding so either the high points or the low points on the edges meet.
        Then miter them.
        Flip one of the lengths of molding end for end and adjust the position so it looks more like a continuous run of rope. around the corner.
        • pbacotP Offline
          zounds!
            pipingguy
            how do you know so darned much sir?
              People like you ask questions and I'd like to help.
                pipingguy
                i tried it without benefit of a left hand plus a right hand rope. close enough. a little sanding and touch-up paint and no one will notice unless they are a basketball player. ๐Ÿ˜„
                some funny stuff in this link........
                http://forums.finehomebuilding.com/breaktime/construction-techniques/rope-molding-outside-corner-miter-tips
                rope molding quandry rev-1.skp
                  CJRyan
                  [attachment=1:x8ufdlau]<!-- ia1 -->Screenshot - 12_5_2017 , 6_43_26 AM.png<!-- ia1 -->[/attachment:x8ufdlau]
                  Then miter them.
                  [attachment=0:x8ufdlau]<!-- ia0 -->Screenshot - 12_5_2017 , 6_49_16 AM.png<!-- ia0 -->[/attachment:x8ufdlau]
                  The "real" trick is to do it in situ. When a number of inside and outside corners have to match.
                  Get the Douzukinoko saw out! For numerous 1/32 inch cuts to adjust the length.
