    DIY Hedges
    14 Posts 8 Posters 23.2k Views 8 Watching
    • PixeroP Offline
      Pixero
      This set of Hornbeam, Boxwood and Thuja twigs requires the Skatter plugin to function properly.
      Have you ever wanted a hedge that had a special size or form and not found a matching ready made 3d model? Now you can easily create Hornbeam, Boxwood or Thuja hedges in any form with this set of twigs and the excellent Skatter plugin.
      Because of the dense nature of Boxwood and Thuja hedges their twigs have cutout branches to avoid the use of very high tracing depth. Materials are set up for Thea render but textures are included for other render engines.
      In each skp file there are example Skattered hedges where you can look at settings and learn from. Open the skp file and start Skatter. Under Renderlist click on edit to load the examples.
      For trimmed hedges:
      Create a low poly boxy hedge with bevelled edges. (With Round corners plugin by Fredo.) Remove bottom polygon and make it a group. Use as Host in Skatter. For some type of hedges there might be need to separate the top part and use shorter twigs there. Remember to hide the Host on a separate layer before rendering.
      For untrimmed hedge (Hornbeam):
      Use the Stem or other geometry as Host in Skatter and use the Hornbeam twigs marked for untrimmed. (They have their pivot point at the bottom.)
      The most important settings in Skatter are:
      Distribution: Random
      Mode: Wrap (UV)
      Density
      Pointing: (Up - Normal. Depends on which model you use.)
      You can also use horizontal mirroring, rotation (try different values for other effects), and Scale.
      Get it here:
      https://sketchucation.com/shop/models/landscape/1969-d-i-y--hedges
      • pbacotP Offline
        Very nice. Good effort. Thanks for providing this!
        • tuna1957T Offline
          tuna1957
          Most excellent ! Thank you very much..
          • I Offline
            ideas_arte
            I bought them a few weeks ago, it's beautiful!
            I did the tests on the SKP files provided, and it works great! but could you please explain to me how I can use it in other SKP models?
            • PixeroP Offline
              Pixero
              Learn the most important settings from the example file.
              Mode: Wrap (UV)
              Density
              Model a low poly model of your choice to use as host in Skatter.
              Copy the twigs to your own SketchUp scene file.
              Try various settings to see how they effect the hedge look.
              Have fun!
              • I Offline
                ideas_arte
                Have fun!
                It's very simple, thanks again Pixero 😳
                Is there any way to take it to the Skatter library?
                  dtrarch
                  Downloads please
                  Vines
                  You sent a payment of $5.60 USD to SketchUcation LLC
                  (mikel@sketchucation.com)
                  D.I.Y Vines - Discount price
                  Item# DC472 $5.60 USD 1 $5.60 USD
                  Hedges
                  D.I.Y. Hedges - Discount price
                  Item# DC471 $5.60 USD 1 $5.60 USD
                  Thank you
                  dtr
                  • PixeroP Offline
                    Pixero
                    See P.M.
                      dtrarch
                      Got them.
                      Thx 👍
                      dtr
                        dtrarch
                        Resolved and thank you
                        dtr
                          jadot73
                          HELLO COULD YOU SEND THE RIGHT PRESET LIKE YOUR PICTURE PLEASE
                          • PixeroP Offline
                            Pixero
                            I downloaded the file just to make sure it was ok and I got this straight out of it.
                            Once the skp is loaded open Skatter and click on the Render list tab.
                            Select one of them and click edit. Click rebuild just to make sure everything is reloaded correctly.
                            Repeat for the rest.
                            Now it should be ok.
                            Study the skatter settings and create your own hedge.
                            Try modifying some values to understand how that changes the appearance.
                              jure1
                              My render is similarly broken as jadot73's. Additionally, the leaves have a thin white border around them (in the viewport and in the render ... what gives?). (SketchUp 2018 trial, metric template).
                              • O Offline
                                orhanskr
                                Hello,
                                I want to purchase this, but did not any tutorial video for extension. Anyone help to me ?
