    [Plugin] Show and Hide your toolbar
    29 Posts 16 Posters 37.3k Views 16 Watching
      @nikus_knx said:
      How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
      AFAIK the Scene Tabs can't be toggled through the API.
      If you were on a PC you could assign a shortcut key to that View > Scene Tabs menu item and then call a WinScript command to mimic the key-stroke, but since it's a 'toggle', then knowing whether you will turn the Tabs on or off is problematical...
      • N Offline
        nikus_knx
        I get it :
        Sketchup.send_action 10534
        Do it two times the first time (there 's a bug in Sketchup about the connected checkbox)
        Enjoy
          @nikus_knx said:
          I get it :
          Enjoy
          However, that's PC only... ๐Ÿ˜•
          Because it's a toggle there's no way of knowing it the tabs are on before running it, so if they are already off it'll switch them on ?
            driven
            on a Mac you can use an osascript call to do the same sort of thing,
            along these lines, but you need to double check all the escapes
            System "osascript -e 'tell application "System\ Events" -e click menu item "Scene\ Tabs" -e of menu 1 of menu bar item "View" -e of menu bar 1 of application process "SketchUp"e- "end tell"'"
            PM me if you want a working version or have a play.
            • biiidB Offline
              biiid
              The gadget very practical,I give it a try.
              • bsintzelB Offline
                bsintzel
                I found the 'Show and Hide your toolbar' plugin to be quite useful when I want to 'snag' a full screen shot that includes a 'lot' of close-up detail -- but without the toolbars. ๐Ÿ‘
                Before this plugin came along, I had to de-select toolbars one at a time to get the screenshot I needed ๐Ÿ‘Ž
                It would be a shame if no-one updated this puppy so that it hides/shows 'only'
                active toolbars. Like Gaieus, I discovered that the current version of this plugin turns on toolbars that I never loaded beforehand. ๐Ÿ˜ฒ
                I've taken obfuscating to a whole new level!
                • BoxB Offline
                  Fullscreen works with 2013
                  http://sketchucation.com/forums/viewtopic.php?p=382150#p382150
                  • bsintzelB Offline
                    bsintzel
                    Precisely what I need. Thanx Box
                      TBA
                      is there any chance to get this helpful tool working for SketchUp 2017 (mac os x)?
                      Atm, itยดs not working.
                      Best regards,
                      Thomas
                        Anton_S
                        There is a better plugin, with a lot more features, such as switching SU fullscreen, called AMS Window Settings. But, unfortunately it's only for Windows.
                          TBA
                          Sorry for the delay.
                          Yes the other plugin is for windows only ๐Ÿ˜ž
                          Any chance that you compile your script for use in SU 2017/2018 ?
                          Best regards,
                          Thomas
                            TerrorEcho
                            @gaieus said:
                            OK, I got it to work, thanks for the help.
                            Same from me, also had this problem and managed to fix it using advices above.
                            shake1S 1 Reply Last reply Reply Quote 0
                            • shake1S Offline
                              shake1 @TerrorEcho
                              Many years have passed, and again there is no way to show\hide toolbar.
                              FullScreen (AMS Window Settings) no longer supports this feature.
                              Any suggestions?
                              • 2 / 2
