    Polygon Positioning Tool
    13 Posts 4 Posters 2.6k Views 4 Watching
    • medeekM Offline
      medeek
      I've got the polygon positioning tool mostly worked out for my foundation plugin. However, when the user enters in a value for the length of the segment (VCB_VALUE) then the subsequent line selection does not properly infer the X and Y axis. I've spent already way too much time on this and I can't figure it out. My code is shown below for the polygon positioning tool:
      # Foundation POSITIONING LOGIC (Polygon)
      module FoundationPositionToolPolygon
      # --------  FOUNDATION POSITIONING TOOL  -----------------------------
      # Positions the foundation assembly. This tool allows the user
      # to place the foundation assembly using the mouse to select a polygon
      class PositionToolPolygon
      	# Show the Ruby Console at startup so we can
      	# see any programming errors we may make.
      	# SKETCHUP_CONSOLE.show
      	#  these are the states that a tool can be in
      	STATE_EDIT = 0 if not defined? STATE_EDIT
      	STATE_PICK = 1 if not defined? STATE_PICK
      	STATE_PICK_2 = 2 if not defined? STATE_PICK_2
      	STATE_PICK_3 = 3 if not defined? STATE_PICK_3
      	STATE_PICK_FINAL = 4 if not defined? STATE_PICK_FINAL
      	STATE_MOVING = 6 if not defined? STATE_MOVING
      	STATE_SELECT = 7 if not defined? STATE_SELECT
      def initialize()
          	@tool_name = "FOUNDATION LOCATOR"
      	@type = "foundation"
      	@pointcount = 0
      def reset
          	@pts = []
          	@state = STATE_PICK
      	@pointcount = 0
          	# This sets the label for the VCB
          	Sketchup;;set_status_text "MEDEEK FOUNDATION", SB_VCB_LABEL
          	Sketchup;;set_status_text "[#{@tool_name}] Click first corner of Polygon"
      	@status_text = "[#{@tool_name}] Click first corner of Polygon"
          	@drawn = false
      def activate
          	@ip1 = Sketchup;;InputPoint.new
          	@ip = Sketchup;;InputPoint.new
          	self.reset
      def deactivate(view)
          view.invalidate if @drawn
          @ip1 = nil
      def onMouseMove(flags, x, y, view)
      	self.set_current_point(x, y, view)
      	Sketchup;;set_status_text @status_text,SB_PROMPT
      def onLButtonDown(flags, x, y, view)
          	self.update_state
      def set_current_point(x, y, view)
          if (!@ip.pick(view, x, y, @ip1))
              return false
          need_draw = true
          # Set the tooltip that will be displayed
          view.tooltip = @ip.tooltip
          # Compute points
          case @state
          when STATE_PICK
              @pts[0] = @ip.position
             	# need_draw = @ip.display? || @drawn
          when STATE_PICK_2
              @pts[1] = @ip.position
      	@sectionlength = @pts[0].distance @pts[1]
      	Sketchup;;set_status_text @sectionlength.to_s, SB_VCB_VALUE
          when STATE_PICK_3
      	@pts[2] = @ip.position
      	@sectionlength = @pts[1].distance @pts[2]
          when STATE_PICK_FINAL
      	@pts[@pointcount] = @ip.position
      	@sectionlength = @pts[@lastpointcount].distance @pts[@pointcount]
          view.invalidate if need_draw
      def update_state
          case @state
          when STATE_PICK
              @ip1.copy! @ip
      	@lastpointcount = @pointcount
      	@pointcount = @pointcount + 1
              Sketchup;;set_status_text "[#{@tool_name}] Click second corner of Polygon"
      	Sketchup;;set_status_text "Section Length", SB_VCB_LABEL
              Sketchup;;set_status_text "", SB_VCB_VALUE
              @state = STATE_PICK_2
      	puts "#{@state} #{@pointcount}"
      	@status_text = "[#{@tool_name}] Click second corner of Polygon"
          when STATE_PICK_2
              # @ip1.clear
      	@ip1.copy! @ip
      	Sketchup;;set_status_text "[#{@tool_name}] Click third corner of Polygon"
              @state = STATE_PICK_3
      	@status_text = "[#{@tool_name}] Click third corner of Polygon"
          when STATE_PICK_3
              # @ip1.clear
      	@ip1.copy! @ip
      	Sketchup;;set_status_text "[#{@tool_name}] Click fourth corner of Polygon"
              @state = STATE_PICK_FINAL
      	@status_text = "[#{@tool_name}] Click fourth corner of Polygon"
      	# @ip1.clear
      	@ip1.copy! @ip
      	ptcurrent = @ip.position
      	@distorigin = @pts[0].distance ptcurrent
      	if (@distorigin > 0.0001)
      		@nextpointcount = @pointcount + 1
      		Sketchup;;set_status_text "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
      		@status_text = "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
      	else
      		# Final point picked, jump to calculation and exit tool to main program
              	self.calculate_obj
              	Sketchup.active_model.select_tool(nil)
      def calculate_obj
      	# Check units of template again
      	lengthconstant = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
       	if (lengthconstant == 0) || (lengthconstant == 1)
      		@Unitstemplate2 = "imperial"
      	else
      		@Unitstemplate2 = "metric"
      	if @Unitstemplate2 == "metric"
      		# Sketchup;;set_status_text "Foundation Width; #{@BuildingSpan_m.round(4)} m - Foundation Length; #{@BuildingLength_m.round(4)} m"
      	else
      		# Sketchup;;set_status_text "Foundation Width; #{@BuildingSpan_ft.round(4)} ft. - Foundation Length; #{@BuildingLength_ft.round(4)} ft."
      	# Back to main program
      	MedeekMethods.main_menu_polygon @pts, @pointcount
      def onCancel(flag, view)
          reset
      def onUserText(text, view)
          # The user may type in something that we can't parse as a length
          # so we set up some exception handling to trap that
          begin
              value = text.to_l
          rescue
              # Error parsing the text
              UI.beep
              value = nil
          return if !value
          case @state
          when STATE_PICK_2
              # update the section length
              vec = @pts[1] - @pts[0]
              if( vec.length > 0.0 )
                  vec.length = value
                  @pts[1] = @pts[0].offset(vec)
                  # view.invalidate
                  self.update_state
          when STATE_PICK_3
              vec = @pts[2] - @pts[1]
                  vec.length = value
                  @pts[2] = @pts[1].offset(vec)
                  # view.invalidate
                  self.update_state
              vec = @pts[@pointcount] - @pts[@lastpointcount]
                  vec.length = value
                  @pts[@pointcount] = @pts[@lastpointcount].offset(vec)
                  # view.invalidate
                  self.update_state
      def getExtents
          bb = Geom;;BoundingBox.new
          case @state
          when STATE_PICK
              # We are getting the first point
              if( @ip.valid? && @ip.display? )
                  bb.add @ip.position
          when STATE_PICK_2
              bb.add @pts[0]
              bb.add @pts[1]
          when STATE_PICK_3
              bb.add @pts[2]
      	bb.add @pts
          return bb
      def onKeyDown(key, rpt, flags, view)
          if( key == CONSTRAIN_MODIFIER_KEY && rpt == 1 )
              @shift_down_time = Time.now
              # if we already have an inference lock, then unlock it
              if( view.inference_locked? )
                  view.lock_inference
              elsif( @state == 0 )
                  view.lock_inference @ip
              elsif( @state == 1 )
                  view.lock_inference @ip, @ip1
      	elsif( @state == 2 )
      	elsif( @state == 3 )
      	elsif( @state == 4 )
      def onKeyUp(key, rpt, flags, view)
              view.inference_locked? &&
              (Time.now - @shift_down_time) > 0.5 )
              view.lock_inference
      # draw a polygon for the outline of the foundation
      def draw(view)
          @drawn = false
          # Show the current input point
              @ip.draw(view)
              @drawn = true
          case @state
          when STATE_PICK
              # do nothing
          when STATE_PICK_2
              # just draw a line from the start to the end point
              view.set_color_from_line(@ip1, @ip)
      	# view.drawing_color = [0, 0, 200]
              inference_locked = view.inference_locked?
      	view.line_width = 2 if inference_locked
      	view.line_width = 2
              view.draw(GL_LINE_STRIP, @pts[0], @pts[1])
              @drawn = true
          when STATE_PICK_3
      	view.line_width = 2
      	# view.draw(GL_LINE_STRIP, @ip1, @ip)
      	view.draw(GL_LINE_STRIP, @pts)
              @drawn = true
          else
      	view.line_width = 2
              @drawn = true
      end # class PositionToolPolygon
      end # module FoundationPositionToolPolygon
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Dan RathbunD Offline
        Dan Rathbun
        Just an FYI, the posted code's improper indentation is so annoying I will not bother to read nor try it out.
        I'm not here much anymore.
        • medeekM Offline
          medeek
          I agree, the indentation is killing me. Trust me it doesn't actually look like this, when I cut and past it into the text box it completely mucks it up.
          design.medeek.com
          • sdmitchS Offline
            sdmitch
            There are two problems as I see it.
            1. You are using @ip1 and @ip to set the line color but, when you enter a length, @ip1 is no longer valid since the point it represents has changed. I think you should use the last to values of the @pts array to set the color.
            2. Expecting the user to get within 0.0001 of the first point to close is way to restrictive.
            http://sdmitch.blogspot.com/
            • medeekM Offline
              medeek
              I replace the set color line with:
              view.set_color_from_line(@pts[@lastpointcount], @pts[@pointcount])
              however the behavior is identical.
              I agree the .0001 is probably too restrictive. What I should probably do is insert a temporary guide point (add_cpoint) and then delete it once I jump back to my main program out of the tool or as the tool terminates. This way the user has something to snap to in order to close out the polygon.
              design.medeek.com
              • sdmitchS Offline
                sdmitch
                I too find it odd that entering a length suddenly causes the axis inference to change its' behavior. The tooltip seems to think that @ip1 is still valid while, if you zoom in and move the mouse very slowly, the correct inference will occur. After that everything is back to normal until the next length entry.
                Very strange indeed and an obvious bug in Sketchup.
                • medeekM Offline
                  medeek
                  Yes it is strange. If you enter a value then the next line won't infer the axis, but if you then click the mouse and begin another line the inference returns to normal. The whole tool thing is still somewhat of a black box to me so I don't really understand it fully but this certainly has me confounded.
                  design.medeek.com
                    Dan Rathbun
                    Nat, use 2 space characters for indents. Tabs will not come out well in the forum code blocks.
                    • medeekM Offline
                      medeek
                      I've been using tabs for indents since 1999, getting me to change now is not easy. You can probably tell that I like a lot of whitespace in my code, easier to read.
                      design.medeek.com
                        Dan Rathbun
                        That is okay (whitespace). I use Notepad++ which automatically replaces TAB with spaces. Each language can have a different indent spacing. (I'd think most editors can [or should] do this.)
                          Garry K
                          I totally agree. I use Notepad++ as well and I do not use tabs.
                          The main reason is everyone can set their tabs differently - but spaces are spaces so the reader gets to see what you want them to see.
                          • medeekM Offline
                            medeek
                            I tried Notepad++ a couple years ago but something about it perturbed me so I went back to my basic Windows Notepad, I may revisit it.
                            design.medeek.com
                              Dan Rathbun
                              @medeek said:
                              ... so I went back to my basic Windows Notepad, ...
                              How do you know what encoding it saves the file it ?
                              How do you know what type of line ending characters it uses ?
                              These are things easily set with a real code editor.
                              In addition code editors use color lexing to help you spell keywords correctly, match up the begins and ends of code blocks, etc. They also can use autocomplete features to help fillout method calls.
                              With your input, this post could be even better šŸ’—
